12-02-2018, 08:05 PM | #1 |
Rep 115
X5 2016 fuel door want open
Hi can someone pls tell me a way of fixing the opening of fuel door. For the past few days I have been opening it manually. It goes upto 25% on the dashboard and the "refuelling possible in" text disappears. When I press the door release button for the second time nothing appears on the dashboard. However, I did notice that before a drive it opens the usual way. Is it to do with the petrol? I pump from the same station. Cannot be an additional pressure inside the fuel tank caused by the petrol.
Many thanks for a quick solution. I have drive this car for more than 4000km and this the first time it happened. Kind regards, Chami
Chaminda Bandara
12-02-2018, 08:37 PM | #3 |
Rep 115
Yes I get out of the car and open the fuel door myself so all 4 doors are unlocked and also the drive ready state is off.
Tks
Chaminda Bandara
12-02-2018, 10:34 PM | #4 | |
Rep 7,160
Also never seen anything that says "refueling possible in..." only the normal fuel low alerts
12-02-2018, 10:42 PM | #5 | |
Rep 2,194
They literally have a wait time or something like that to open the fuel door. |
12-02-2018, 10:46 PM | #6 | ||
Rep 7,160
Violator4587.50 |
12-03-2018, 07:32 AM | #7 | |||
Rep 115
Chaminda Bandara
06-15-2019, 10:07 PM | #8 |
Rep 80
Drives: 2018 330i xDrive Gran Turismo
This started happening to ours the last two times we tried to fill up. Seems that i3’s have similar problem. After we get the fail message we can still push on the door to open it. Have not had to resort to using the manual release in the trunk. Will have to have the dealer fix it.
2018 330i xDrive Gran Turismo - Mineral White, Coral Red Interior
2016 Mazda Mazda3 GT - Deep Crystal Blue Mica, Off-white Interior 2007 Four Winns Horizon 190 |
06-16-2019, 06:12 AM | #9 |
Rep 131
Have same problem with my 40e and have to always pull the release lever (open tailgate and open small compartment, right side)
I guess due to the fact that I do not use it too often, as I mostly drive short distances via eletric drive. Someone told me BMW replaces some sensor or whatsoever, but I rather pull the lever, than going to BMW dealer. Try WD-40 at locking bolt, this worked out for me. |
06-16-2019, 08:29 AM | #10 | |
Rep 115
Take care,
Chaminda Bandara
Dasun_krishantha0.00 |
06-17-2019, 09:40 AM | #11 | ||
Rep 3
06-17-2019, 09:44 AM | #12 | ||
Rep 3
06-22-2019, 07:18 PM | #13 |
Rep 80
We dropped off ours at the dealer to look at it on Monday. The last fill-up we had to resort to pulling the green cord in the trunk.
06-23-2019, 11:44 PM | #15 | |
Rep 115
Also please let me know if the door opens okay early morning or before the very first journey for the day. Mine opened without any issue and had issues only after driving for a while where pressure builds up in the fuel tank. Thanks
Chaminda Bandara
06-25-2019, 09:26 PM | #16 |
Rep 80
They found fault codes for the failed pressure sensor and replaced it. Part number 16-14-7-426-702. They had to remove rear bottom seat cushion to access it.
06-22-2020, 06:48 PM | #18 |
Rep 2
There is an extended LIMITED WARRANTY EXTENSION
If you have a failed FUEL TANK PRESSURE SENSOR on an i3 i8 and or X5 PHEV this repair is covered. Heres a link. https://static.nhtsa.gov/odi/tsbs/20...45289-9999.pdf
hope this helps. I have the malfunction of the door latch opening and the fuel system malfunction with a check engine light on a 2017 BMW X5 40e. I will be bringing the car to the dealer tomorrow. I think this is my problem. wish me luck! |
06-25-2020, 02:51 PM | #19 |
Rep 2
Just got the X5 from the dealer. I told them about the problem of the fuel door switch not opening the fuel door. I also had check engine light and fuel system malfunction light. I got the car back after about two hours of work from the dealer. It was a faulty fuel pressure sensor. Dealer replaced the faulty fuel pressure sensor. Now the fuel door switch works perfect. Check engine light is gone. The work was done free of charge. My 2017 is still under warranty plus there is a TSB that states the i3, i8 and X5 40e are covered. Hopefully all Is good from here on out.
06-26-2020, 05:52 AM | #20 | |
Rep 131
