      04-18-2021, 07:37 PM   #1
Fxcardo
Drives: 2017 BMW X6 50i
Emergency call malfunction
Has this happened to anybody else on here? Tried searching on the forum but found nothing came up. Car is no longer under warranty since Feb of this year so I want to see if there is a fix I can do. Thanks in advance.
      04-18-2021, 08:29 PM   #2
DenBel
232
Drives: F15 50i, F13 650i
Could be atm battery
CatalinP589.50
      04-19-2021, 10:03 AM   #3
Fxcardo
Thank you, but did you mean agm battery?
      04-19-2021, 11:01 AM   #4
CatalinP
Drives: BMW X5 F15 2014 3.0xd
No, ATM, the telematics module.
      04-19-2021, 01:17 PM   #5
Fxcardo
The battery inside of this?
      04-19-2021, 01:21 PM   #6
RED_Y_
Drives: 2014 X5 3.5d
Yes, check this video out, same problem:
      04-19-2021, 01:25 PM   #7
DenBel
232
Yours is most likely white box attached to the roof antenna, but the procedure is similar
      04-19-2021, 01:27 PM   #8
Fxcardo
Thank you guys so much! Going to pop open the back roof liner as I'm assuming that's where it is on the x6 and check what's going on back there. Appreciate all the help!
      12-20-2021, 10:12 AM   #9
Dodongd
Drives: X5 2017 F15
I have same problem with white Telematic box attached under shark fin antenna, i changed the battery and still a problem. Do i need to code reset the sos? please help. thanks
      12-20-2021, 10:20 AM   #10
CatalinP
It is mandatory to perform error reset function in ISTA+ (or other 3rd party software) after such operation.
ISTA+ will also tell you exactly what the problem is and generate a measures plan to solve it.
      07-07-2022, 07:47 PM   #11
c00lbeans
14
Drives: X5 40e
What is the part number for the battery?
      07-10-2022, 02:18 PM   #12
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Your shark fin might be getting water in it and made this error.
Happened to both my G05 and G07
