      09-18-2018, 04:06 PM   #1
Jase1125
Drives: 2016 X5 in Jet Black
Grimlins running amok
I took my X5 to the dealer a couple of days ago. They completed warranty work:
* replaced the steering column
* looked into adaptive headlight malfunction and replaced a component
* updated the software per adapter headlight bulletin that was out
I picked up the car this morning and all seemed normal. I just lost all my coding options because of the software update. When I got home, I updated the coding with Carly. Disabled seatbelt warnings, enabled video in motion and a few other minor changes. Everything seemed good and no problems. I finish up and go inside. Several hours later I need to run to the store and started the vehicle and all hell broke loose. I restore all coding backups and it changed fixed nothing:
* windshield wipers stuck on
* pedestrian detection malfunction
* cruise control malfunction
* collision warning malfunction
* blinkers don’t work
* all buttons on steering wheel do not work
What is the likelihood this is caused by a bad code? Everything was put back to defaults and even disconnected the battery. I ended up returning to the dealer so they have it now. I ran diagnostics and it found “interface ssl / fem / bdc (operating steering column switch, 0x1ee): signal invalid.”
      09-18-2018, 04:39 PM   #2
TheUltimateDrivingManiac
Freude am Fahren.
Drives: F15 X5 xDrive35i
Has nothing to do with the coding. Something wrong with a new steering column, may be bad contact.
Freude am Fahren.
      09-18-2018, 04:47 PM   #3
Jase1125
Thanks, that was my guess based on that code. However, I wasn’t certain.
      09-18-2018, 04:56 PM   #4
turboawd
1641
Drives: 2015 X5 35i
Sometimes a weak battery can do weird things.
      09-20-2018, 04:06 PM   #5
Jase1125
It appears this might be a corrupt / bad FDL module. Dealer is replacing to see if that resolves the problem.
      09-21-2018, 05:46 PM   #6
Jase1125
Well that didn’t help either
      09-21-2018, 06:10 PM   #7
calucb05
Drives: F15 35d M-Sport
G01 BMW X3 M40i  [0.00]
Keep us posted. Took my car in and dealer updated software and all my coding was gone. Was planning on redoing it this weekend but wondering if I should hold off now. I also use Carly.
      09-21-2018, 10:12 PM   #8
Jase1125
I was told now they are replacing some other module. They didn’t identify which one. If that resolves the issue, it should be noted on the service paperwork or I will ask. This is quiet weird.
      09-26-2018, 05:55 PM   #9
Jase1125
The BDC module had to be replaced. Apparently a blown internal fuse.
      09-27-2018, 03:34 AM   #10
mpowered5
mpowered5's Avatar
433
Drives: E34 M5
What issue did you have with the adaptive headlights?
2015 X5 35d M sport
2017 340i M sport
1991 M5
1988 M5
      09-28-2018, 06:02 PM   #11
Jase1125
They changed a part. Cannot remember and don’t have the paperwork.
