07-03-2019, 10:10 AM | #1 |
78
Rep 320
6wb retrofit
Anybody located in Germany that can help me with a 6WB retrofit? The cluster is used and virginized. Im being told it needs to have the ECU flashed to work properly.
07-03-2019, 10:20 AM | #2 |
Rep 1,915
Mine was virginized, but it works OK, except the navigation, which will require cluster flushing. No ECU flash, at least from what my coder told me.
I know somebody who can do the cluster flash, if that's what you mean. |
07-03-2019, 11:28 AM | #3 |
Rep 2,514
No ECU flash needed,just code it. If cluster is properly virginized just follow the guide here
https://f15.bimmerpost.com/forums/sh....php?t=1039855 Super easy. Takes about 20 minutes to code. |
07-03-2019, 12:15 PM | #5 |
Rep 2,514
Not sure what CAFD file are you talking about? Do you have E-sys and PSDZData files? There is nothing to flash in the cluster except VIN and milage, but that is part of the virginizing process.
07-03-2019, 04:52 PM | #7 | ||
Rep 2,514
Did you check the guide in the retrofit thread? To inject the CAFD you need to Quote:
And you also did step 1 fromt he guide? Quote:
07-04-2019, 02:03 AM | #8 | |||
78
Rep 320
07-04-2019, 07:04 AM | #9 | |
Rep 1,915
Looks like this was being passed along w/o being virginized?? |
07-04-2019, 09:13 PM | #10 |
Rep 92
I have the 6wb also I've been meaning to Install, could you tell me what your cofer charged to "revirginize" your cluster? was it a simple coding?
cheers! |
07-05-2019, 12:26 AM | #11 | |
Rep 2,514
Update: This gentleman here https://f15.bimmerpost.com/forums/member.php?u=197043 Last edited by RED_Y_; 07-05-2019 at 12:29 AM.. Reason: Found the guy |
