03-15-2018, 03:07 PM | #1 |
Rep 184
Upgraded Charge-Air-Coolers for the X5M
these new charge-air-coolers are out now for the M5/M6 and they will have a kit available very soon so they will fit the X5M/X6M. they're 28% bigger then the stock charge-air-coolers which should provide a significant amount of additional cooling that will translate into a decent horse power gain.
I was thinking about throwing a meth kit on for when i run race gas but i might get a set of these first. thoughts????
2016 X5M
JB4, DME Tune, Full Custom Fab Worx Exhaust w/ Straight Pipes and Cutouts, KW V3, 22" BC Forged Wheels, Brembo BBK on all 4 corners |
03-15-2018, 03:19 PM | #2 |
Rep 4,532
Truly depends on your goals. I've had multiple AtA and AtW Hx on my 427TT. One rule I have proven over and over and over....A larger Hx properly designed is always "nicer", but a HP increase is not always guaranteed with an inlet charge temp decrease. It's VERY complicated. I've also used Meth on 3 of my other TT builds. Definitely works, but the amount sprayed has to be figured, etc, etc.
If you are building a Max Effort X5M and will run 24-30psi, I'd do both. If you're running 21-22psi, you'll spend $ and time for little to no gain. Above is a very rough summary and guideline, but it will "ballpark" it for you. |
Travis1807108.50 ajob463.50 |
03-15-2018, 04:25 PM | #3 | |
Rep 184
any suggestions would be appreciated. you think i would see better gains from the meth then compared to the larger coolers??
2016 X5M
03-15-2018, 04:36 PM | #4 |
Rep 4,532
Above is my rolling test bed. I’ve had 8 different turbo systems, 3 different ecms, 6 different Hx systems,etc etc on the car. With what you currently have done, plus future plans to add an ECM tune.....I would add Meth and spend the money on the most sophisticated system you can find PLUS do it with the ECM tune to make sure the AF was perfect and the SOI , Rate, etc was perfect. I would also confirm everything on a load dyno with the tuner present to confirm the tune was working properly for your combo. I’d pass on the Hx upgrade for your goals. |
Travis1807108.50 DarthCharger0.00 |
03-15-2018, 04:38 PM | #5 | |
Rep 184
2016 X5M
03-16-2018, 04:07 PM | #6 |
182
Rep 321
I have found that sometimes with larger intercoolers and piping your torque curve will change. You can get more power on the higher end, but you can lose the power on the lower end. At what part of the torque curve to you want results. Street or track.
03-16-2018, 05:26 PM | #7 |
Rep 184
I was hoping for across the entire RPM range hp gains but I’m guessing that would be more otainable from a meth kit.
03-19-2018, 08:24 AM | #8 |
Rep 8,835
I think you would run into the limitation of the transmission before you run into the need for additional cooling. The X5M has the best cooling system i've every experienced with any car. I could park leave the thing idling and the temps would start dropping on its own even in 95 degree temps.
Unless you plan on running this thing at the track I wouldn't think cooling would be necessary.
Travis1807108.50 |
03-20-2018, 03:14 PM | #9 | |
Rep 184
2016 X5M
03-20-2018, 11:24 PM | #10 | |
Expect the Unusual
259
Rep 1,344
Also, I remember one time hustling a 2015 Merc SLK 300 on Mulholland. 10 minutes on Mulholland and then got to a stoplight. As I'm sitting there, I notice a bunch of smoke around the car, but there's a big truck in front of me and I think it's the truck's exhaust. Nope. All 4 of the Merc's brakes were emitting heavy white smoke. LOL. I pulled over and it had to have been at least 3 or 4 minutes since the last hard braking and the rotors were still bright red. Surprised they didn't seize while I was stopped at the light for a minute. I knew they were hot though, so I was slowly inching forward trying not to keep the pads locked. But man, talk about insufficient brakes for that car. Conversely, Porsche sure knows how to design brakes (or help Brembo with a proprietary formula). The steel brakes on my 981 never faded. Ever. And yet, I've gotten fade plenty of time with much bigger, much more expensive carbon ceramics. Last edited by BMWCali; 03-20-2018 at 11:33 PM.. |
11-21-2023, 06:15 PM | #12 |
Rep 116
I know it's an old bump, I know the part numbers on the F90 and F10 Charge coolers are different than the F85's, but is there any reason why an F90 cooler wouldn't bolt up?
