05-04-2016, 06:04 PM | #2377 |
Rep 2,404
05-04-2016, 08:37 PM | #2378 | |
Rep 938
05-04-2016, 09:22 PM | #2379 | |
Rep 592
Didn't you tried adding 2TB and changed the values for paddles verbaut no niktactiv and started getting errors? |
05-04-2016, 09:34 PM | #2380 |
Rep 938
Added 2tb. It worked but car would pop into a manual gear randomly when driving. Assume it's because I didn't disable paddles but haven't tried that.
Feshas had sport + set but since I haven't vo coded again I can't confirm all that is needed. I can say feshas alone won't do it. |
05-04-2016, 10:08 PM | #2381 | |
Rep 592
05-05-2016, 04:45 PM | #2382 | |
Rep 2,404
The codes below is what I would try to turn on to get Sport+, I would guess 90% of these are already active on your car. <<< CAFD_0000023F.caf.016_016_033 (GKEB23) >>> GKEB23 > Applikation 3000 > Sportschalter = aktiv GKEB23 > Applikation 3000 > Sportschalter_alt = aktiv <<< CAFD_00001543.caf.000_054_002 (LMV_01) >>> LMV_01 > Fahrzeug-Basisdaten 3001 > Getriebetyp = Automatik <<< CAFD_000013D8.caf.003_002_002 (ICMQL) >>> ICMQL > DSC_ICM_CODIERDATEN 300A > FesHasMode5 = aktiv <<< CAFD_000017BE.caf.005_031_151 (BDC_01) >>> BDC_01 > SfSvdVcmGlobal 3210 > VCM_TYPE_GEARBOX = automatik BDC_01 > TcIntegration 3022 > TCI_STARTLOCK_NO_HW_PARK_SIGNAL = aktiv BDC_01 > TcIntegration 3022 > TCI_TYPE_OF_GEARBOX = Wert_02 BDC_01 > TcMaster 3020 > TCM_STARTLOCK_BRAKE = aktiv BDC_01 > TcMaster 3020 > TCM_STARTLOCK_CLUTCH = nicht_aktiv BDC_01 > TcMaster 3020 > TCM_STARTLOCK_DRIVINGREADINESS = aktiv BDC_01 > TcMaster 3020 > TCM_STARTLOCK_PARK = aktiv <<< CAFD_00000069.caf.010_001_110 (KOMBI L6 BO) >>> KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_SIGNAL_1 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_SIGNAL_2 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_SIGNAL_3 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_SIGNAL_4 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_TEXT_1 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_TEXT_2 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_TEXT_3 = menue_3 KOMBI L6 BO > ECO_FDS 300C > FDS_MENUE_TEXT_4 = menue_3 KOMBI L6 BO > KI_Dimmung 3007 > FDS_MENUE = menue_3 <<< CAFD_0000146B.caf.031_000_022 (PMA_PDC) >>> PMA_PDC > PDC_ERROR 300E > ueberwachung_getriebetyp = automatik PMA_PDC > PDC_VARIANT 300A > automatik_getriebe = aktiv Last edited by dsad1; 05-05-2016 at 04:58 PM.. |
05-06-2016, 04:22 PM | #2383 |
Rep 65
In BDC_BODY? I couldn't find that parameter. I searched the entire module for the word "UNLOCK" and didn't come across anything else that looked like a possibility. Any other ideas? Thanks!
05-06-2016, 06:25 PM | #2384 |
Rep 592
05-06-2016, 08:31 PM | #2385 |
Rep 2,404
quick question, when you guys have the drivers door open, will the car let you drive? I don't drive the x5 much, but on the other bmw it would never let me. Not sure if I coded something by mistake to allow this to happen, or if it's like this by default on the x5.
05-06-2016, 09:07 PM | #2386 | |
Rep 3,990
05-06-2016, 09:17 PM | #2387 |
Rep 2,404
Yeah that is what I thought, but for some reason the x5 is letting me now drive with door open. I will test it again later to see if it was just a fluke, or if some code caused this.
05-06-2016, 09:21 PM | #2388 |
Rep 424
I can move my X5 with the door open as long as I Don't remove my foot completely from the brake pedal.
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1 -xHP Transmission Flash 2014 X5 50i Carbon Black/ M Sport -BM3 Stage 1 |
05-06-2016, 09:22 PM | #2389 | |
Rep 3,990
Yes, delvi is correct. If you completely remove foot from brake, the car will shift into Park. |
05-06-2016, 09:23 PM | #2390 |
Rep 2,404
Maybe that is what it was then, I was for sure riding the brake. Although in the 6 series it wouldn't even let me do that. It would stop the car as soon as it rolled.
05-06-2016, 09:27 PM | #2391 |
Rep 424
both my 2007 4.8i and my 2011 35d E70 acted just like your 6 series if I open the door it was like spring loaded in to Park, a pain to try to drive on to ramps to work on them.
05-07-2016, 01:17 AM | #2392 | ||
Rep 8,364
05-07-2016, 10:05 AM | #2393 | |
Rep 3,456
Drives: Harrop E90 M3
05-08-2016, 01:51 AM | #2395 |
Rep 8,364
05-08-2016, 11:17 AM | #2396 |
Rep 205
E-SYS on high resolution displays
Running E-sys v.3.27.1 and launcher v2.53.108 and it appears poorly adapted to the high res display on my samsung laptop. The dialog boxes are nearly unusable. I was able to get it installed and connected to the car but can't go further simply because I can't see everything.
I tried the high-res fix checkbox while the launcher is starting but it has no effect. Is there a command line code or something I can use to fix this? Searched and found nothing... Using windows 10. Plain vanilla fresh install. My guess is I have a unique problem. |
05-08-2016, 07:12 PM | #2398 |
Rep 41,048
PM sent.
