05-21-2017, 02:47 PM | #3455 |
Rep 40,928
Not via Coding. Only way is a non-coding solution. PM sent.
05-22-2017, 09:16 PM | #3456 |
Rep 256
Drives: '17 F15 MSport
Shawn, have a 2017 X5 can you pm me link for the latest software?
05-22-2017, 09:34 PM | #3457 |
Rep 40,928
PM sent.
05-23-2017, 02:07 PM | #3459 |
Rep 8,364
05-23-2017, 03:34 PM | #3460 |
Rep 176
05-23-2017, 03:40 PM | #3461 |
Rep 8,364
05-24-2017, 07:15 AM | #3462 |
Rep 91
Trailer coding message
Great thread, I've used this as a reference more than I can count.
I installed and retrofitted a OEM harness for my F15 X5, I coded the module 3AC in FA/FP. Updated the CAFD and I'm still getting this error. Any ideas? |
05-24-2017, 11:37 AM | #3463 |
Rep 8,364
You coded which modules? HC2, DSC, ICM, BDC, HKFM, KOMBI, HU_NBT, iCAM?
05-25-2017, 10:36 PM | #3464 |
Rep 91
05-25-2017, 11:26 PM | #3465 |
Rep 40,928
05-27-2017, 09:14 AM | #3467 |
Rep 40,928
PM sent.
05-29-2017, 07:06 PM | #3468 |
Rep 453
Shaun I have a brand new x5 e can you please email me a link to the latest software? Also I have searched and not found the answer - I need to add AM Radio as a band choice. Any idea how I would do that?
Thanks in advance! |
05-29-2017, 07:48 PM | #3469 | |
Rep 40,928
For AM Radio band, FDL Code HU_NBT => RADIO_BAND_KW to Aktiv:
05-30-2017, 12:18 AM | #3470 | ||
Rep 61
Yes, I coded my mirrors to automatically open/close, the navy and radio to turn off once you open the door, I can open close the doors, windows sunroof from either the door handle, or the key fob I got the windows to stop rolling up if the door gets opened (front or rear) I got rid of the warning disclaimers, reset the seatbelt chime from 100 seconds to 30, enabled fog lamps to stay on with high beams, or just the parking lights, I adjusted the brightness of the daytime driving lights (front and rear) I can open/ close the tailgate from the switch inside or via the fob (and even stop it in the middle of it if has a possibility of hitting a garage ceiling, video in motion, video from USB playback, changes the colors of the interior LED lights, enabled the door handle lights to turn on in reverse (for more viability at night while backing up). I got the TPMS to also measure tire temperature as well as pressure... I enabled the lane departure warning to be on all the time, as well as the proximity sensors. I could even change the sound of the car alarm to euro or British sounds as opposed to USA And those are just the presets! There is an expert mode to code additional features. There are also a bunch of other presets, but I have 3 keys, and it was getting late, apparently, you have to have only one key in the car at a time, but it's well worth the headache. I still have some other things I want to program as well, like and easy entry/exit driver's seat, and the temperature of the heated/vented seats. Tons of options, and most are presets! I also enabled the adaptive headlights. Make sure you also download the free BimmerLink app (from the same guy) to clear out any fault codes. Once that's done, it kicks ass! Best part is, it saves backups of everything you did so you can always revert back to stock, and if you use it in another vehicle, it separates the changes based on vin#, so you can code as many cars as you'd like!
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package |
Almaretto2374.00 |
05-30-2017, 08:48 PM | #3472 |
Rep 40,928
PM sent.
05-31-2017, 06:36 AM | #3473 |
Rep 185
Hello shawnsheridan,
What tools can I use to see and clear fault codes on my 16 40e ? I tried via e-sys transmitter clear all DTC, but I still have the fault. Is it possible to get some links and instructions ? Thanks in advance! |
05-31-2017, 06:58 AM | #3474 |
Rep 40,928
PM sent.
05-31-2017, 09:33 AM | #3475 |
Rep 13
Help!!
I VO coded my entire ECU...and I am now getting a drivetrain malfunction. I tried clearing all the DTS warnings using ESYS but the warning still presists. I would appreciate anyone's help on this. Thank you so much. |
05-31-2017, 10:17 AM | #3476 |
Rep 13
Dear shawnsheridan,
I am new to this post. But after reviewing other threads, I saw that you had experience with my problem. May you please advise on what I can do to solve this issue. Thinking of taking the car to the dealer. Also non of the coding that I did (window roll up, seatbelt warming, ex.) applied. Only the drivetrain malfunction occurred. Thank you for all your help. |
