12-07-2014, 06:29 PM | #705 |
Rep 156
well i try to >>AC will remember if ‘Off’ or ‘On’ from previous shutdown>> MEMORY_OFF and MEMORY_UMLUFT, but i have some issues
1.- i do not have IHKA just IHKA2 2.- inside there is only MEMORY_UMLUFT on 3000 not on 3003 like the codesheet 2.- and i cant find MEMORY_OFF anywhere. thanks guys. |
12-07-2014, 06:34 PM | #706 | |
Rep 3,990
I have corrected the cheat sheet to IHKA2 and OFF_MEMORY.
12-07-2014, 09:47 PM | #707 |
Rep 27
This is correct. For me, OFF_MEMORY was already set to aktiv, so I just made change only to MEMORY_UMLUFT to aktiv and verified that this worked. My AC is now turned off when I start the car now.
12-09-2014, 12:17 AM | #708 | |
267
Rep 345
Drives: 2019 X5 40i M
2019 X5 X40iM
12-09-2014, 12:19 AM | #709 | |
267
Rep 345
Thanks
2019 X5 X40iM
12-10-2014, 12:10 PM | #710 | |
Rep 1,181
My current setting is strange, too. There is a combo value vs just the F015_ohne. How are multiple values even able to be selected? I tried using the Ctrl key, but that didn't work. I decided to not save/code the new values until I could ask the question and get confirmation here. Thanks as always. |
12-10-2014, 12:52 PM | #711 | |
Rep 3,990
Variable light distribution Yes FEM_BODY 3073 C_AFS_ENA nitch_aktiv aktiv Variable light distribution Yes FEM_BODY 3073 LUT_FLC_FORWARDLIGHTING_Y 9C 9C B0 9C 9C 9C Here's an F80 thread quote to confirm: "I did not modify FA but I went back to the car and did following: FEM_BODY 3073 C_AFS_ENA - Changed F020 disabled/F030 disabled to F030 enabled (I found that it was available) FEM_BODY 3073 LUT_FLC_FORWARDLIGHTING_Y - Changed F020Codierwert ohne AFS, F030Codierwert ohne AFS (9C 9C B0) to F030Codierwert mit AFS which displayed 9C 9C 9C value. <---I don't remember if these were the exact names but it's something like it. Bottom line, VLD worked." Obviously for our purposes, FEM_BODY is BDC_Body.
12-10-2014, 01:27 PM | #712 |
Rep 1,181
Thanks for the Lightning fast and detailed response my friend. Will see if VLD lowers my angst level with the LEDs. Or maybe I'll whine even more since the lights will dance around now.
12-10-2014, 01:29 PM | #713 |
Rep 3,990
Any time, bud .
12-10-2014, 03:17 PM | #714 |
Rep 578
Thank You Opasha
I just wanna to say THANK YOU dear @opasha For your time, patience and everything last week when we finally code my car
Unfortunately, some code won't work until I finally retrofit my 10" NBT, but at least, now I have SPORTS DISPLAY and Memory ACC Thanks buddy!!! You are the best! Enrique PS: Code via Macbook Pro with Ethernet adapter and using Parallels! plus r33 ENET cable, of course Last edited by LatinBimmer; 12-10-2014 at 04:02 PM.. |
12-10-2014, 10:35 PM | #715 | |
Rep 13
12-11-2014, 11:48 PM | #716 |
Rep 170
@LatinBimmer, great to hear that opasha was helpful. He is a world of resources and he is going to help me this weekend. Can't wait!
I also have Macbook Pro / bought cable from R33 / and using VMware for windows. Glad that set up worked so it puts me at ease. |
12-12-2014, 01:35 AM | #717 | |
Rep 1,181
The minute the coding was complete, I saw the headlights start to re-calibrate, with the driver's side moving independently from the passenger side. Looking forward to driving it tomorrow night to see how it behaves. |
12-12-2014, 02:11 PM | #719 |
Rep 3,990
We don't what that coding does. VLD is already complete. You're referring to Anti-Glare. We can't use those codes if the recalibration has no effect.
12-12-2014, 03:54 PM | #720 | |
Rep 208
12-12-2014, 08:13 PM | #721 |
Rep 3,990
Yeah, I know, but those were all theorized fdl code changes. We don't know what they actually do for the anti-dazzle parameters. @skalberti, can you send those changes to @blinders and see if it changes anything for him since he was the only successful one at recalibrating his F15 so far? Thanks.
12-13-2014, 05:17 AM | #723 |
Rep 3,990
Sorry, just did. Didn't realize how full it got in the last few days .
12-13-2014, 01:36 PM | #724 |
Rep 666
Is there a way to make it default to the last driving mode on startup instead of always starting in comfort? I went through the coding cheat sheet and couldn't find anything about it.
What about defaulting auto-hold to on? |
12-13-2014, 02:10 PM | #725 | |
Rep 3,990
Unfortunately, there is no coding for the last used Mode or for automatic Auto-H.
12-13-2014, 06:43 PM | #726 |
Rep 1
Coding ACC
I have Active Cruise Control on my 2015 X5d. Even at the shortest distance, it leaves too much room in front of me (2-3 seconds at 75 mph/120 km/h), so I ether have people constantly cutting from the right (I live in the US where there is no lane discipline), I have to stay in the right lane behind the slower traffic, or just not use the cruise control. I see that there is a code change to change the default from 4 (the most ******* to 1 (the shortest), but is there any way to change the following distance in each of the steps? Failing that, can I just disable the ACC and go back to regular cruise control? Thanks to anyone who can help.
