09-17-2019, 06:51 PM | #1 |
Rep 53
Sorry - front license plate bracket screws to bumper
Can anybody please point me to a proper size/type of screw to use for this?
Have the OEM bracket but NO screws with it that I can find. Yes I searched. No, please don't say "don't drill into the bumper!!!///one" or otherwise try to steer me away from just mounting it as intended lol. Already been pulled over numerous times and front plate does not bother me in the least. None of the threads I found mentioned actual correct screw size/type and/or merely focused on alternative mounting methods that I'm not interested in. Does the bracket just screw right into the bumper plastic itself? The few threads I found that weren't just whining about putting the bumper on mentioned "self tapping" screws but I don't see why this is necessary if it's just screwing into plastic and makes me wonder if there's some backing plate or bumper support that gets screwed into. Anybody have OEM screws you could measure and/or snap a pic of? Thanks |
09-17-2019, 07:09 PM | #2 |
Rep 234
According to Realoem the part number is: 07149240740.
https://www.realoem.com/bmw/enUS/sho...diagId=51_9423 I just recently installed mine. Holes were already in my bumper from a previous owner, and I had the original screws. I notice that realoem part number is not the self tapping screw. The ones I had were self tapping. And there is no backing it goes through the bumper and is held by only the thickness of the bumper. |
09-17-2019, 07:31 PM | #3 |
Rep 249
I had to use dorman license plate fasteners after I found my plate frame on the floor. Some idiot backed into it while parking and stripped the holes. With the fasteners it’s a larger hole but it’s more secure than just screws alone.
09-18-2019, 07:31 AM | #4 | |
Rep 53
Thanks guys - guess I'll just get something generic since it merely screws direct into the bumper. |
09-18-2019, 03:12 PM | #5 |
Rep 249
They have different size fasteners. It will make the hole slightly larger than the standard plate screw but in my situation the hole was already larger due to the screw stripping the bumper. With the fastener I can say for sure, thing is not coming off easy.
