      11-08-2020, 03:29 PM   #1
campaign308
Drives: 08 X3
Oil You Guys Use ?
I’ve been looking at ditching BMW branded oil for my oil changes, nothing wrong with it but as we all know it’s just rebranded. I’m looking to switch for something I can easily pick up at the parts store.
From research BMW switched to Pennzoil for recommend brand. I found Pennzoil Platinum European Formula Ultra SAE 5W-30 LL-04 readily available also found Mobile 1 Euro Formula 0W-40 LL-01. Just wanted to see what you guys are currently running.
      11-08-2020, 04:21 PM   #2
RED_Y_
Drives: 2014 X5 3.5d
What engine do you have? 3 liter one?
      11-08-2020, 04:24 PM   #3
campaign308
Drives: 08 X3
4.4N63TU
      11-08-2020, 06:31 PM   #4
DenBel
232
Drives: F15 50i, F13 650i
Advanced auto parts
      11-08-2020, 06:49 PM   #5
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
Mobil 1 0W-40
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      11-08-2020, 07:33 PM   #6
ponytuning
121
Drives: '16 F16 50i, 15' F15 50i
Bmw 0w-30 on f15 and f16 both n63tu
      11-08-2020, 08:18 PM   #7
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
Liqui Moly
      11-08-2020, 08:58 PM   #8
KCTiger
Drives: 2016 X5M
Liqui Moly Liechtlauf
      11-08-2020, 09:11 PM   #9
JMAN1111
Drives: F86 Black Fire X6M, F16 X6 50i
Only run liqui moly
      11-08-2020, 09:48 PM   #10
Sophisticated Redneck
Drives: 2012 BMW X5 50i
As others have mentioned, use Liqui Moly Liechtlauf 5-40 plus 1.5 cans Ceratec additive (only Ceratec once every 50K, use 1.5 cans Mos2 additive for all other oil changes)
Original N63, 160,000 miles, ran leak down test at 150K miles when I fixed the valve stem seals, all cylinders within 5%, bearing surfaces on cams looked excellent, with just stage 1 tune and a laggy transmission that has about a second delay between shifts (don't listen to BMW kids, your transmission oil is NOT lifetime) I am still belting out low 4 second 1-foot 0-60 times. Not to shabby for a 8 year old 160,000+ mile 5300lb tank. I attribute much of this to the superior protection this oil and the additives gives.
The N63 and all variants run hot, the 5-40 really shines here however if you are in a very cold climate, you will want to reach out to LiquiMoly for recommendation on what viscosity to use. They have excellent tech support.
      11-09-2020, 02:37 AM   #11
bmwchue
Drives: 2013 bmw 328i
I got the same vehicle and for its first oil change im going to use mobil 1 0w40
I have been using that in my f30 328i for 3 years now but I only do oil changes like 2 to 3 times a year because I don't drive much
      11-09-2020, 10:15 PM   #12
c00lbeans
14
Drives: X5 40e
You guys have any thoughts on rotella t6 w5-40?
Used it on my WRX for 10 years. And a lot of other car forums love it for turbo cars.
      11-10-2020, 04:44 PM   #13
turboawd
1636
Drives: 2015 X5 35i
Diesel oils have more zinc, which is not good for catalytic converters.
Personally I use mobil 1 or castrol euro oil that I can buy at Walmart Cheap.
      11-10-2020, 06:55 PM   #14
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
Wow...those wear surfaces are pristine. Impressive.
      11-10-2020, 07:04 PM   #15
pennsiveguy
As turboawd mentions, oils designed for diesel engines have a specialized additive package. I ran Rotella T 15w40 in Caterpillar diesel heavy truck engines years ago. The main contaminate in that application was soot, and the additive package in Rotella T was designed to mitigate its effects. It would have been completely mistaken to therefore assume that the same oil would have been well advised for the gasoline-powered high-compression leaded-gas automotive engines I was putzing with at the time. Additives are the most expensive components of an oil formulation; oil blenders don't just throw in "a little of this and a little of that" to make their oils universally applicable.
      11-11-2020, 02:05 PM   #16
mikado463
mikado463's Avatar
Drives: 2017 x5 35i , '67 Corvette BB,
good points on Rotella (as well as other diesel oils) and to add to that the fact that if you're still running a flat tappet cam(older weekend toys perhaps) , they have zinc as part of the additive package which is an important lubricant.
As for our modern vehicles and synthetics, I started using Amsoil in '76, zero issues.
cheers - Dave
      11-17-2020, 05:22 PM   #17
epenbecks
Drives: x5 f15
First time did oil change for my f15 sdrive35 since i bought it last February. Went to the car shop and the mechanic show me that he has to use the bmw oil as recommended. I don't mind since he quote the same price as if i use liqui moly.
Glad to find this thread, so i can see what other oil good for this engine.
      11-18-2020, 04:54 AM   #18
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
LIQUI-Moly for both my F15d and F10 550i. Blackstone lab tests show very good results at 7k change intervals in both.
      11-18-2020, 06:34 AM   #19
Kshawn
@powahungree72
Kshawn's Avatar
Drives: 2017 X5 XDRIVE50
Liqui Moly💯
