02-07-2017, 01:25 AM | #1 |
Rep 123
A friend has given me set of 22" Hartge wheels that were on a 2014 x6m. I do realize that the rear hub size on the x6m is different than the rear hub size on my soon to arrive 2017 X5 m sport diesel.
The wheels are 22x10.5 for the front and 22x12 for the rear. They came with H&R adapters/spacers. I test fitted the front Hartge with the wheel spacer/adapters that came with them on my 2014 X5 diesel m sport and hey for perfect, the included h and r spacers made the wheel sit perfectly. My problem is the rears. I think the x6m hat these wheels came off have 72.56mm rear hubs not 74mm all the way around like the non M x5's. The front on M x6 is the same as non M that's why the fronts worked perfect. Also the wheels say for BMW E70 only stamped on the inside spoke of all 4 wheels. I would have thought hat this would have bolted right up to my f15 since the hubs are he same on the e70 and f15. However the hub size on the rear of the Hartge looks like much too large when I take the h and r rear spacer/adapter out and it's too too tight with the spacer/adapter in. Please see photos attached. Any help is appreciated. Brian |
02-07-2017, 09:15 AM | #2 |
Rep 18,713
You need to get the wheel center bore opened up and get a new pair of spacer.
How think of spacers are you using for both front and rear?
02-07-2017, 11:51 AM | #3 |
Rep 85
dont they sell special adapters?
or hubcentric rings? something like this? http://www.ebay.com/itm/SET-OF-4-HUB...NWmXq2&vxp=mtr Last edited by belarus27; 02-07-2017 at 11:52 AM.. Reason: link provided |
02-07-2017, 04:44 PM | #4 |
Rep 123
I have 17mm rears and thinner ones for the front i didn't measure he front ones yet. I just found out after talking to HR at the spacers/adapters that came with these wheels were made by H&R Germany specifically for Hartge. H and R cannot make me a new set for the rears that have the correct center bar for my ex five they have no part number or no knowledge of this custom-made part for hartge. What I really need to do is be able to contact hartge Germany and have them send me out a new set of rear spacer/adapters that fit my hub and this wheel any ideas on how to reach them??
02-07-2017, 04:45 PM | #5 |
Rep 123
02-07-2017, 10:22 PM | #6 | |
Rep 18,713
You may be able to find some hub ring adapter. Just need a new set of spacer.
