09-23-2017, 07:11 PM | #1 |
Rep 15
Tire Pressure low message on X5
Hi,
Does anyone ever experience a Tires Pressure low. Do not drive over 80 miles and etc. I have a 2017 X5 with run flat tires 315/35 R 20 . I took my car to a tires shop but they couldn't find anything wrong with the tires. They checked tire pressure and it was normal. I appreciate if someone can share their experience or answer my question. Thank you. Thaigrr |
09-23-2017, 09:39 PM | #2 |
Rep 8,364
When you fill up tires, sometimes you need to reset system. And, only if one tire is low will warning trigger. So, if all are low, then there is no message.
Did you check pressure in IDrive? |
09-27-2017, 03:31 PM | #3 |
Rep 666
I've found that all four of mine will report low when we get a cold front. Like if it was 102 yesterday and 70 today -- better not need to get anywhere fast, cuz the car will probably ask for air.
09-27-2017, 03:53 PM | #4 |
Rep 8,364
I am vigilant about checking pressure and have portable compressor to make adjustments.
