02-08-2017, 11:46 AM | #1 |
1148
Rep 2,426
Rear window washer pump fuse
I got a low fluid warning, tried to top up to no avail. Then my rear washer stopped working. No motor sound at all. Front ones still work.
Wanted to check maybe fuse but pamphlet says service required. Is there fuse I can check? I'd rather not pull the fender when I'm still in warranty so I would go to dealer but that's a hassle.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
02-08-2017, 03:14 PM | #2 |
Rep 748
Ones Low fluid warning is on a rear motor is disabled. I learned it during the coding and was able to bypass this restriction. What do you mean by saying :
02-08-2017, 04:20 PM | #3 | |
1148
Rep 2,426
I keep getting the low washer fluid warning on the dash, but I'm not low on fluid. I guess the sensor is broken or something. I scheduled a service to have the dealer take a look. Curious if you remember the parameter I need to change to bypass this restriction with the rear motor?
BMW CCA 509766 Last edited by alphaod; 02-08-2017 at 04:27 PM.. |
02-08-2017, 07:32 PM | #4 | ||
Rep 748
02-08-2017, 08:24 PM | #5 | |
Rep 8,364
Software will also have step-by-step diagrams. |
