02-17-2017, 06:57 PM | #1 |
Rep 853
Brake service: What mileage did you change your brakes?
Current kms 30k.
My OBC says the 'rear's' need service in 8000kms and fronts in 14000km. I do 80% hwy. Is the OBC accurate? Has anyone taken their x5 in and just got the brakes inspected and didn't need a change?
2018 540ix msport
2015 X5 msport 2013 750ix msport 2011 550ix msport 2009 e92 335i msport |
02-17-2017, 06:59 PM | #2 |
1150
Rep 2,426
Well I assume if the CBS reads brakes need they will replace them if under the maintenance (at least it was on my E70). They replaced pads and rotors even though both still had some life left. If you're out of maintenance, I would just skip the dealer and go indy/self.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
02-17-2017, 07:04 PM | #3 | |
Rep 853
2018 540ix msport
02-17-2017, 07:11 PM | #4 |
Rep 11,891
based on my experience with the CBS on the E70 X5, it's pretty accurate. When I got the big red warnings on changing my front rotors, when I did change it, I used the standard caliper measuring tool and behold, it measured exactly at the required minimum thickness for the OE rotors.
Pads still had some life left, but I changed it out anyways.
02-17-2017, 07:42 PM | #5 |
1150
Rep 2,426
In that case, I would skip the dealer and do it yourself. Just take off the wheel and check when the CBS says you need to replace.
BMW CCA 509766 |
02-20-2017, 04:31 PM | #6 |
Rep 570
02-21-2017, 12:36 PM | #8 |
Rep 11,891
some manufacturers are okay if you change your pads, then turn your rotors...BMW doesn't do that. Should you turn your rotors if they're above their minimum thickness? Up to you...it's not like turning rotors is free either, and you're not extending the service life all that much if you're owning the car for the long term
MrTookies457.50 |
02-21-2017, 02:30 PM | #9 |
Rep 525
i have a complete brake setup from my 2014 50i that i removed for a bmw BBK upgrade....ill let it go if someone pays shipping and $200 for the metal sitting in my garage
02-21-2017, 07:05 PM | #11 |
1150
Rep 2,426
Some cars like Mercedes and Porsche I noticed the pads are couple mm smaller than the disc itself, so after the rotor disc wears down you get this little lip. I don't know why they do that, but I find you need to replace the pads and the rotor.
But on our BMWs the pads seem to be about the same size as the disc, so it's all worn down, therefore unless my rotors are under a safe thickness I see no reason to replace them.
BMW CCA 509766 |
02-21-2017, 07:08 PM | #12 |
1150
Rep 2,426
I'm really tempted, but then I'll just end up with metal sitting in my garage. For example I have enough motor oil and filters lying around good for another five oil changes.
BMW CCA 509766 |
02-23-2017, 10:33 AM | #14 |
Rep 1,547
I reset the service indicator twice on mine (before swapping out to the MPBK). Lots of pad left when I pulled them off, could've got another 15-20k out of them.
02-24-2017, 08:33 PM | #15 |
Retired Curmudgeon
2985
Rep 4,047
This isn't new. They've been doing it since I have owned BMWs (1994). They're designed to wear at about the same rate under "normal" usage. No one I know has "normal" usage.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
02-27-2017, 11:05 AM | #16 | |
Rep 570
