      10-14-2017, 07:13 PM   #441
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Is there any way to open wastegates on demand?
      10-15-2017, 04:09 PM   #442
Aptem-k
Drives: BMW X5
Is it possible to code colors in ambient lighting in bimmercode. When I open mine, instead of color codes I see some strange values. Or I have to add new value with code of color?
      10-15-2017, 10:44 PM   #443
Jay89
Drives: X5 & M3C
I can't code for trunk open/close (power tailgate module) with key fob since its grey on the dot it stead of green. it says unknown ECU
      10-16-2017, 04:59 AM   #444
Aptem-k
Drives: BMW X5
I have the same issue. Can somebody help with that?
      10-16-2017, 09:53 AM   #445
SCA
SCA's Avatar
Drives: Multiple BMWs
Do you have ‘slow communication’ turned on in settings?
      10-16-2017, 09:56 AM   #446
monkiboy
Dominican Republic
535
Drives: '17 x5 3.5i w/MPPK & MPE
yes, the developer. did you email him? he will provide a solution and/or status on the solution.
      10-16-2017, 11:01 AM   #447
Aptem-k
Drives: BMW X5
Yes, slow communication is “on”
      10-16-2017, 05:39 PM   #448
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
I was successful in coding this evening.
There was one module in for some logo that had x5 and x6 ...the last option i couldnt figure it out bunch of letters.. what is that?
      10-16-2017, 08:44 PM   #449
JStang
JStang's Avatar
562
Drives: FDB M3 CS
Can you guys confirm that this is the VGate I need?
https://www.amazon.com/Vgate-ELN327-...+ii+wifi&psc=1
      10-16-2017, 08:52 PM   #450
shezi01
Drives: BMX X5 35i
Yes that is the one i got last week and it works. ( it comes with instruction to download the torque (google play) and some app for apple just ignore that).
JStang562.00
      10-16-2017, 08:53 PM   #451
monkiboy
Dominican Republic
535
go the app website and just click the amazon link to purchase. supports the developer and makes sure you get the correct product.
JStang562.00
      10-16-2017, 08:58 PM   #452
shezi01
Drives: BMX X5 35i
Was able to successfully code my x5 with the app using android device. Developer has code clearing built into it and don't need additional app. Not bad at all for under $60.
Coded the following:
1. Tail gate closing with button on the driver door.
2. Tail gate closing with remote key fob.
3. Remove the disclaimer.
4. added the M in the headunit for start up display.
5. Added turn signals to HUD.
6. Fogs with high beam.
7. Tried but didn't work turn signal x 5. ( will troubleshoot this further when i get a chance this weekend).
8. Mirrors unfolding with comfort access.
i couldn't find the setting where i can switch on fogs with headlights ( headlight are set to auto, but fogs don't turn on with it).
My door handle lights already turn on with reverse. Probably will look into coding additional items as time goes on.
      10-17-2017, 07:03 AM   #453
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
what is mpm_logo_mpm?
its under the cluster module...
the codes clear itself after reboot, only time i had to do it manually.
on welcoming light section...
what should it be..several items
"hard on"
what is this feature?
      10-17-2017, 11:29 AM   #454
OFFWHITEX5
Drives: WHITE BMW X5 35i AWD M-SPORT
Quick question guys. Is there a towbar code area (rear view camera zoom) on one of the modules using the V-Gate and BimmerCode?
      10-17-2017, 01:42 PM   #455
Aptem-k
Drives: BMW X5
See https://docs.google.com/spreadsheets...e9s4/htmlview# row 13
      10-17-2017, 01:54 PM   #456
OFFWHITEX5
THANK YOU Aptem-k I never even knew this sheet existed. I bookmarked it.
      10-17-2017, 02:27 PM   #457
Aptem-k
Drives: BMW X5
So did anybody managed to change ambient lighting colors via bimmercode?
      10-17-2017, 04:33 PM   #458
Jay89
Drives: X5 & M3C
is there any way for me to use this bimmercode app to change blind spot notification on different speed limit?
      10-20-2017, 05:12 PM   #459
kj71109
Drives: 24 X5 40i
Well bought the adaptor and app in hopes of being able to code my angel eyes back to 100% for DRL function, but the app doesn't seem to support the location of that ECU. The TMS I believe is where I need to be. Any help would be appreciated. I had anti dazzle coded by code my car and for some reason it dimmed my DRL down. It's driving me crazy.
      10-22-2017, 07:58 PM   #460
JStang
JStang's Avatar
562
Drives: FDB M3 CS
I just coded mine and could not get the turn signal to accept 5 blinks either. It would automatically change to 1. I emailed them to fix it.
EDIT: After reading through all 21 pages this seems to be common.
      10-23-2017, 10:18 AM   #461
Doanster
Doanster's Avatar
627
Since I use ESys via laptop and not the app, I'm only speculating here. The problem may be that the app is not recognizing which I-Step level people are on and modifying the appropriate BDC_BODY module?
That is, for older I-Step levels, the function to modify was BLINKZYKLEN_ANZAHL_TIPP in Module 3068 and it actually gave you the ability to program four blinks if you wished.
Newer I-Step levels, the function to modify is PIA_DEFAULT_TIPPBLINKEN in Module 3069 and it appears you have the choice of one, three, or five blinks only.
Also, if you check the box of "Triple Blink" in iDrive... it'll erase your freshly coded setting of five blinks. That's what happened to me yesterday.
      10-23-2017, 10:22 AM   #462
boyce89976
Drives: 2014 X5 5.0 M Sport
Originally Posted by eggyacid View Post
Hmmm, interested in
- hatch close from the door button (I think I already did this, will check this weekend)
- added turn signals to HUD
- Rear daytime running lights (is this similar to rear fog in European countries?
I keep seeing "hatch open/close from the door button". My X5 does this stock. You push the tailgate button to open it and pull it up and hold to close it.
