      01-23-2020, 01:19 PM   #23
smyles
Drives: '21 X5
I suggest to also inspect DME and its connections, and check continuity/resistance on both ends of the wiring.
Not sure if such scenario is possible in F series, but back in E46 and leaking sensors days I had shorted DME due to oil sipping thru wiring.
      01-23-2020, 01:27 PM   #24
faboR6
Drives: 08 135i
Still waiting to hear from my mechanic. He told me this morning a wire was slightly split near the ground for cylinders 1 and 2. Im hoping it was that. Thanks for the advice. That will be my next step if it doesn't.
      02-27-2020, 08:25 AM   #25
faboR6
Drives: 08 135i
Originally Posted by faboR6 View Post
Originally Posted by EdgyE36 View Post
FWIW - this sounds somewhat similar to a recent video I watched. It's on an older E36, but cylinder was dead and it wasn't plug or coil. It was coil driver, fixed by replacing a fuse in the DME.
Thank you this could be another option. My mechanic found one wire leading to cylinder 1s coil with a small split. He fixed it with electrical tape but still doing the same thing. He is still inspecting the rest of the harness as of now.
All injectors were replaced this week with misfires still happening in cylinders 1 and 2. I'm almost certain now that it's the DME. Anyone have recommendations and where to send it off to get it diagnosed or repaired. Im thinking it might be the mosfets.
      02-27-2020, 08:27 PM   #26
~ViO~
~ViO~'s Avatar
53
Drives: 2013 X6M, 2015 X6 50i
How about a good old fashioned disconnect of the negative battery cable for about 20 minutes... And see if resolves the issue.. Will cost zero to try.
      02-27-2020, 09:39 PM   #27
DenBel
232
Drives: F15 50i, F13 650i
You should use the Bosch coils as Bosch is the only manufacturer for n63tu engine. For the first version of n63 Delphi is manufacturer. Besides if you run the part numbers listed on Fcp web site in Delphi coil description non of those numbers is compatible with n63tu. I had a misfire and did some research, so bought Bosch coils and Bosch pugs from fcp and the misfire gone. So my suggestion to try Bosch coils
      02-27-2020, 09:41 PM   #28
faboR6
Drives: 08 135i
Everything is Bosch. I tried doing the battery disconnect for a whole day it didn't work.
      02-27-2020, 09:42 PM   #29
DenBel
232
Did you try to swap the old coils before replacing them?
      02-27-2020, 09:46 PM   #30
faboR6
Drives: 08 135i
Yes tried everything. Have moved coils and spark and it does not matter what's in cylinders 1 and 2 no spark is coming out from there. Compression test was done as well and everything is normal. Seems like the DME or CPU shut those cylinders down completely or those mosfets from the DME are done.
      02-27-2020, 09:52 PM   #31
DenBel
232
I just mentioned that yours is 3.5 sdrive. Did you try to diagnose that issue with ISTA?
      02-28-2020, 06:39 AM   #32
Chicane_S54
Chicane_S54's Avatar
37
Drives: F15 X5
Exclamation
Have you backprobed the coils with an oscilloscope and voltmeter and actually tested if they are getting the proper signal? Have you tested the resistance on the wires? How do you know that it is not the wiring? You can't just replace components without testing the wiring. The DME will purposely shut down cylinders if it feels some action is so out of range that it will damage the engine. that is what it is supposed to do. Have you connected the vehicle to ISTA+?
      02-28-2020, 06:43 AM   #33
faboR6
Drives: 08 135i
The vehicle has been at the shop since I posted this. It's a good BMW INDY Shop in AZ. I'm going off what they are telling me. Although I don't think the wiring harness has been looked at.
      02-28-2020, 06:44 AM   #34
Chicane_S54
37
Drives: F15 X5
Question
Did you reset the injector flow rate in ISTA after replacement?
      02-28-2020, 06:49 AM   #35
faboR6
Drives: 08 135i
They did the calibration after the installation if that's what your referring to. I'll give them a call today with all this and see what they tell me.
      02-29-2020, 02:44 AM   #36
Twin Peaks
N00B
Twin Peaks's Avatar
Drives: X5 50i (F15)
I had a similar issue, ended up being a bad MAF. Have them review voltage of the two and/or switch them and clear codes.
The owls are not what they seem!
beattiecj127.50
      02-29-2020, 12:30 PM   #37
Rob09msport
Drives: 09 335 msport
If your n63tu fcp gives wrong coils they are updating website I had to call and tell them. They give gn10571 instead of gn10328
      02-29-2020, 12:31 PM   #38
Rob09msport
Real oem lists delphi not Bosch for the tu
      10-10-2021, 05:51 PM   #39
M3Char
Drives: 2007 E92 M3
Any update on this mate
      07-12-2022, 11:28 PM   #40
schung
Drives: 6MT AW 335i Coupe
Bumped for update? Experiencing similar issues
      01-16-2023, 09:51 AM   #41
NewAlbanyX5F1535i
Drives: 2017 BMW X5 x35i M sport
They did the calibration after the installation if that's what you’re referring to. I'll give them a call today with all this and see what they tell me.
was this ever resolved ?
      08-28-2023, 07:49 PM   #42
Yoyo1980
Drives: X6M 5.0i
Hi,
Same problem here. Mine is cylinder 5; replace all the spark plugs, swap the coils around but the problem stay with cylinder 5. However, when swapped the wire connected to the coils between 5 and 6 ; 6 started misfiring as well. So my guess is to check the wire at this point.
Any help or suggestions would be appreciated
      11-17-2023, 09:15 PM   #43
beattiecj
beattiecj's Avatar
128
Drives: 2012 135i 2017 x5 35i 1988 e30
Any resolution to this? Would be nice to see a solution.
