09-11-2021, 02:37 PM | #1 |
Rep 740
Cold start stalling, 35i
Hey all,
So I've been having this issue randomly where it would stall on cold start. Start it back up and its fine. It only does it when the engine is cold. Now it seems like it does it every cold start. Anyone else have this issue? '14 x35i, 92k miles, stock.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
09-11-2021, 02:41 PM | #2 |
Rep 252
Any codes? Have you done plugs and coils? How about carbon buildup, ever looked at the intake valves or had media blasting? Not the only things, but the usual first suspects. Also high pressure fuel pump..
My current BMW vehicles:
SUV Convertible Sedan Lots of burbles and POPS |
09-11-2021, 02:45 PM | #3 |
Rep 740
I did the plugs about 25k miles ago. Coil's are original. I didnt think the carbon buildup on the n55 were as bad as the n54's from what read awhile back. The car doesn't struggle or take longer to start so I ruled out HPFP for now. I'll have to take a video on the next cold start.
09-11-2021, 02:48 PM | #4 | |
Rep 252
09-11-2021, 02:50 PM | #5 |
Rep 252
If all is fine and it literally just dies, mass air flow sensor should be checked too.
09-11-2021, 02:53 PM | #6 |
Rep 252
low pressure fuel pump / filter ever been changed? Just throwing things out that can make it die after a start, but it would be easier to go down the list and rule things out.
SUV Convertible Sedan Lots of burbles and POPS Last edited by VWAudi2BMW; 09-11-2021 at 03:09 PM.. |
09-11-2021, 04:59 PM | #7 |
Rep 178
What's your current ilevel?
When was the last time the car was programmed |
09-12-2021, 07:45 AM | #8 |
Rep 553
What work has been done lately? I've heard transmissions with issues or needing adaptations run can do this. Lots a factors need to be eliminated first. I'd also be curious to look at the duty cycle of the fuel pump as well.
09-12-2021, 04:56 PM | #10 |
Rep 1,687
Drives: 2014 428i and 2018 X5
MAF sensor and throttle body cleaned????
02-09-2022, 06:14 PM | #11 |
Rep 740
Quick update, took it to the dealer and they updated the software. Its been a few weeks and no stalls. Crossing fingers.
02-09-2022, 07:09 PM | #12 |
Rep 172
02-09-2022, 08:30 PM | #13 |
Insta~ f10_sapphire
158
Rep 412
Must be a temp solution. If it's a real issue then the issue will soon return. Do you think a weak battery can also be a factor?
Insta ~ f10_shapphire
02-09-2022, 10:29 PM | #14 |
134
Rep 305
I had exact same issue for almost a year...engine would stall out and die on various cold starts. Worst was when i was skiing and car would barely start or stay on. For a while the dealer said no problem, then i left it for days so they could reproduce the issue. Once they acknowledged the issue, dealer said software would fix problem, which sounded silly to me. But they did a software update and I've had zero issues and no stalling in about 8 months since.
I have extended warranty so they could have fixed anything and it would have been covered, so they had no incentive to not fix something if broken. I assumed I'd be back when the cold start idle shut down occurred again, but here i am, many months later and issue is gone. Ive been skiing a bunch since December and not one issue in the cold this winter. |
02-09-2022, 11:51 PM | #16 | |
Rep 5,002
Ours did this for a few weeks then it just stopped doing it. I’ve never seen it stall tho. I was thinking either software or injectors. |
02-10-2022, 12:47 AM | #17 |
134
Rep 305
Yes...sometimes shudder...sometimes stall. Mostly shuddering in beginning. Stalls happened more towards end (before fix), but it was also colder months at that time. Would've put money on something physical needing replacement, but software update fixed it. Only downside was i lost all my coding and had to spend time recoding everything.
02-10-2022, 08:02 AM | #18 |
Rep 740
I paid a diag fee at the dealer and they said that the software was too old and had to update the car first before they can diag any further. I guess after the update, they let the car sit for a few extra days and the car didn't stall. Paid a little under $600 and no stall so far.
02-10-2022, 10:36 AM | #20 |
Rep 740
If you're under warranty, they would cover the update but I'm out of warranty lol.
02-10-2022, 11:30 AM | #21 |
Rep 5,002
02-10-2022, 12:19 PM | #22 |
Rep 807
Drives: BMW X5 XDrive35i
Start with a software update and go from there. Injector failure isn't uncommon at that mileage.
