      11-20-2015, 10:00 PM   #111
///M3PIMP
Drives: 2003 ///M3
My 15 mm front spacers broke when I torqued them down.
You couldn't tell while installed but easily noticeable once the wheel was removed.
When I removed the wheel to check on the damage the wheel and tire fell straight to the floor. Be careful when removing your wheel if the hub has broken there will be nothing to hold the wheel in place once the bolts have been removed.
      11-23-2015, 10:42 AM   #112
stewy604
stewy604's Avatar
289
I use two alignment rods that help prevent this from happening. They also help when re-installing the wheels, as these 20's (especially the rears) are rather heavy.
2007 Suzuki GSX-R 750
      11-24-2015, 02:14 PM   #113
///M3PIMP
Drives: 2003 ///M3
^^^ That's a good idea
      11-24-2015, 02:46 PM   #114
BayX5
Drives: F85 X5M
When are we going to know if 5 mm works on the fronts?
      11-24-2015, 02:52 PM   #115
Tomorrow. I've been trying to steal the X5 from my wife, but she needs it.
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
      11-24-2015, 03:21 PM   #116
BayX5
Drives: F85 X5M
Doesn't your wife have s-drive? Isn't the whole issue that the spacers are to small for x-drive hub but not s-drive?
      11-24-2015, 03:23 PM   #117
Yes, but the 5mm is not about sDrive or xDrive.
The 5mm front is just to see what is the best combo.
I did check the 10mm, it won't since it has the hub lip. While the 5mm is just slide on.
I am hoping 5mm and 15mm will look as good.
      11-24-2015, 03:55 PM   #118
BayX5
Drives: F85 X5M
Ah. Ok
      11-24-2015, 06:49 PM   #119
///M3PIMP
Drives: 2003 ///M3
I'm pretty happy so far with the 20s in the rear.
I thought they might have been too aggressive at first, but now after seeing the car being driven and from a distance the 20s definitely give it a bulldog look. Flush with the wheel arches.
I think 5 mm in the front will get it almost flush to the front wheel arches.
I just received the painted front reflectors from Ben.
Now I can't wait to get the 5 mm spacers so that I can do both jobs at once !
      11-25-2015, 04:05 PM   #120
Here is the picture with 5/15mm combo.
I think it looks really good.
      11-25-2015, 04:06 PM   #121
damn app.
      11-25-2015, 04:26 PM   #122
BayX5
Drives: F85 X5M
Are the H&R springs still on it?
      11-25-2015, 04:40 PM   #123
No. Car is stock height.
      11-26-2015, 09:51 AM   #124
stewy604
stewy604's Avatar
289
Looks good Ben. I've still gotta pull a wheel this weekend and check my front hubs. Been too busy to spend any time in the garage.
      11-30-2015, 12:48 AM   #125
butchlv
Drives: 2015 x5 35i
Ben, when the 5mm/15mm are available I would like to purchased them from u and get u to code my 2015 x5 x drive 35i as well.
      11-30-2015, 02:20 AM   #126
elisiX
elisiX's Avatar
Australia
687
Drives: '20 X3M Competition
They do look really good.
Are you planning on throwing the H&R springs back on?
      11-30-2015, 02:30 PM   #127
It is available.
Just PM me if you want it.
That last picture is customer car, not mine.
My X5 is done already. So no more mods going in.
      01-07-2016, 05:09 PM   #128
Update: 15mm spacer will fit on the F15 X5 front for production date before 11/14.
After MY11/14, BMW changed the front hub where 15mm spacer won't sit flush against the brake rotor hat.
      01-08-2016, 09:56 AM   #129
stewy604
stewy604's Avatar
289
Still loving the look and stance on the 15/20 & ACS springs on mine. IMO, the height and stance is the way it should ship from factory.
      01-09-2016, 10:38 AM   #130
///M3PIMP
Drives: 2003 ///M3
^15/20?
Is your X5 Sdrive, or does it have an earlier production date?
My X5 is Xdrive '16 so I couldn't use the 15 fronts.
RGsport sent me the 5 mm for the front and even though they are thin, it pushes the wheel and tire to almost flush with the fender.
I'm very happy with my 5/20 MM set up with M adaptive suspension ride height.
Ben, I still have the extended bolts to send back to you.
      01-09-2016, 03:33 PM   #131
^15/20?
Send them back, so I can give you the credit.
stewy604 car is early production year.
      01-11-2016, 10:41 AM   #132
stewy604
stewy604's Avatar
289
^15/20?
Hey M3PIMP, mine is an Xdrive 35d, but with a production date in April 2014.
Search this Thread:
Advanced Search
