05-20-2015, 08:40 PM | #1 |
Rep 1,886
How to Get Weather Info While Widget Ist Kaput
You also get a more extended and more granular weather report this way. I simply programmed it into one of the memory keys for quick access.
The split screen widget has been very spotty the last three months. This is a workaround for access to weather info.
05-20-2015, 08:42 PM | #2 |
Rep 1,448
I can't get the link to work on my iPad.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
05-20-2015, 10:31 PM | #3 |
Rep 781
This is what I have always done, so I don't understand how this is a workaround. Can you explain please
05-20-2015, 10:59 PM | #4 | |
Rep 1,886
Why were you hiding your approach from us ?
05-21-2015, 09:27 AM | #6 |
Rep 781
I just didn't know didn't know I was hiding anything. I've been trying to get the analog clock to show up in split screen, but I don't see that option
05-21-2015, 09:40 AM | #7 |
Rep 1,448
Apparently there is still no way to show the weather in the split screen which is what I need since I am on the open road very dependent on the main nav screen.
I did follow the video instructions just to see what would happen and I could not even get weather like that illustrated by the OP.
05-21-2015, 09:48 AM | #8 | |
Rep 1,886
Analog clock: - split screen contents > scroll down to bmw widgets > clock, from three choices at the end of the menu tree. |
05-21-2015, 09:24 PM | #9 |
Rep 781
05-22-2015, 07:36 AM | #10 |
Rep 132
My normal setup is XM Radio or Media on the left and the Weather Clock on the right.
I can have the XM Radio on the right and do this Weather info screen on the left, but if you want to stream music which I do, then that info can only be displayed on the left. Its a big mess, but like I said a few posts ago, the weather info is there, it even auto updates your location, so when I called BMW several times they said there was an issue with the Vendor. Well thats BS, because the Vendor is currently providing the Weather info, but IMO BMW cannot figure out how to enable the WX Widget or something. Lame |
05-22-2015, 08:43 AM | #11 |
Rep 1,886
bothfly , yep, it is BMW. Weather info even shows up on the navi map (provided you have selected to show that info), when you zoom out.
