      11-29-2023, 06:53 AM   #1
pass427
Drives: BMW F01 and F85
Can some one check labor time on this job for me
So I took my car in due to a drivetrain malfunction and the tech indicated that it was oil control solenoid failure bank 2 and they will need to change both and he quoted me 6hrs, sounds like that's long for two solenoid but I ain't no tech so I figure I would ask. Car is a 2018
F85 Black Sapphire Edition
      11-29-2023, 04:09 PM   #2
CryptoHeff
CryptoHeff's Avatar
Drives: BMW X5M
VANOS solenoid, right?
I can't vouch for hours as I don't know how long it would take, but I've looked into the procedures on ISTA and it is a heap of work for what in the end is a pretty simple replacement.
The issue is you need to remove quite a bit to get to them. The right hand side was about 30 pages of instructions/images factoring everything in. And the left side was even more from memory.
I had a similar malfunction recently and cleared the codes and it hasn't happened again since. Mine happened on a rough cold start.
I ended up buying four solenoids intending to eventually do all of them...
      11-30-2023, 06:35 AM   #3
lemonslap
Drives: BMW X5M
Same happened to me once on cold start, BMW assist came out and cleared the codes and it hasn’t happened since.
      12-01-2023, 09:40 AM   #4
pass427
Thanks guys - receipt states it took them 5hrs so i guess its all the other stuff they had to move to get to it - they replaced 2 solenoid valve part # 11-36-8-605-123.
The codes that were present were fault code 131601 Vanos Exhaust 2 not controllable and 120908 charging pressure control 2.
Warranty covered it, only had to pay the difference as I wanted oem parts as oppose to aftermarket.
