11-14-2016, 07:53 PM | #1 |
Rep 968
Tire rotation yes or no
Do I need to rotate tires at the time of balancing?
BMW service manager said not required since its AWD. Discount tires said wrong advice. Tires should be rotated whether car is awd or 2wd. Car in the question is 2015 X5 x35i with 19" stock Pirelli tires. |
11-14-2016, 09:00 PM | #2 |
<3 Flat Four
217
Rep 754
tires should always be rotated, depending on the tread pattern of the tires. either front to back, or side to side, or cross pattern
2011 335is Le Mans Blue
11-14-2016, 09:38 PM | #3 |
1151
Rep 2,426
I never rotate tires on 4WD SUVs.
But that's just me though I've never had a problem. Granted my setup is staggered so rotation isn't even possible. |
nyalpine907436.00 Dirty Cash206.50 |
11-14-2016, 10:16 PM | #4 |
Rep 968
11-15-2016, 05:41 AM | #5 |
Rep 11,846
Drives: MY24 G01 AW Msport
if you have stagger setup, where rears have wider tires then no.
if all 4 tires are same width then yes. |
11-15-2016, 08:10 AM | #6 |
<3 Flat Four
217
Rep 754
u can still rotate staggered setups as long as the tires aren't directional
11-15-2016, 08:46 AM | #8 |
Rep 211
nyalpine907436.00 |
11-15-2016, 09:34 AM | #9 |
Rep 425
When I replaced the tires on our '14 X5d at ~36K miles, with 19" wheels on a square setup, the difference in tread depth across 12 readings (3 across the tread width on each of 4 tires) was 1 mm with the exception of two readings which were 2 mm different. From my experience rotation is not only unnecessary, but would not provide a benefit.
11-15-2016, 09:52 AM | #11 |
Rep 1,547
I would only rotate them if you're getting uneven wear.
11-15-2016, 10:02 AM | #12 |
Rep 2,527
If directional and staggered, and you really motivated to do it, then you'd have to unmount the tires and swap them side to side to keep them facing the same direction.
11-15-2016, 10:59 AM | #13 |
Rep 108
I have 20" staggered setup so cannot rotate front-rear.
I was looking at the tires and it looks like all 4 corners have some negative camber. Do others with the wider tires notice if the inner tread wears quicker than the outer tread? On my 911 I unmount the rears and remount them on the opposite side to even out the wear across the tread and try to get a few more miles out of those wide tires. Does anybody do this with their X5? |
11-15-2016, 02:52 PM | #14 |
Rep 781
I have the 19" Pirelli Scorpions on my X5 and have been rotating them every 5k. My tire wear is very even and the cost to rotate is minimal. Seems like a good way to get the max wear out of the tires. I see no downside.
Capttom5000.00 |
11-16-2016, 05:39 AM | #15 |
Rep 110
Drives: 2024 X5 M60i
Never rotate if you care about performance
BitteEinBit34.50 |
11-16-2016, 10:18 AM | #16 |
Rep 1,547
Common on most BMW's with the way the suspension is setup from factory. I had an alignment done after I lowered the vehicle and added my Conti DWS06. I definitely had inner wear on my outgoing P-Zeros.
11-17-2016, 10:12 AM | #17 |
Rep 747
Same, and discount tire rotates tires for free!
09-25-2017, 04:31 AM | #18 |
Rep 437
Drives: 2011 E92 335i AW
Sorry to resurrect an older thread, but I figure it's better than starting a new one. I'm getting an uneven wear on my 2015 X5 F15 at almost 20k miles. Car is pretty much bone stock with 19" 255 Goodyear Eagle RFT tires. Oddly enough the front tires have significant more wear than the rear. I was under the impression that BMW Xdrive is a rear biased system so if anything shouldn't the rear be more worn? I've since rotated my tires but can't help but wonder if there's something not right with my car?
09-25-2017, 05:07 AM | #19 | |
Rep 124
09-25-2017, 01:24 PM | #21 | |
163
Rep 317
But the flip side is driving overly careful to prevent wear is no fun!
2016 X5 35i color: Jet Black
2014 Audi Q5 Premier Plus color: Ibis White Last edited by expidia; 09-25-2017 at 07:43 PM.. |
