XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      09-22-2017, 06:24 AM   #1
Bmwlover x
25
Drives: X6
Pre-2014 N63 (not N63TU) engine lifespan?
Hello. How long can these engines last? At what millage they need changing tensioner, chain, injectors and so on. Please write from your experience. What was faulty on your 50i and at what millage. Thank you.
P.S.
Please write when was your car produced and it has black engine cover or grey.
      10-01-2017, 05:40 PM   #2
Bmwlover x
25
Drives: X6
Is anything new?
      10-22-2017, 10:12 AM   #3
Bmwlover x
25
Drives: X6
up .
      10-22-2017, 11:37 AM   #4
TrAcK TRaP
bOrN To DiE
Drives: 2011 E92 M3 ZCP
Engine life? It will pass 300K for sure. Just do 5k oil change and all required maintenance..
      11-05-2017, 07:06 AM   #5
Bmwlover x
25
Drives: X6
Many people say that it burns oil after 40k. Chain , tensioner and some parts must be changed after 50k. Is not it right?
      11-05-2017, 09:24 AM   #6
Frankkao14
Drives: 2012 BMW X6 50i
My 2012 X6 50i (Black Engine Cover) starting to burn oil after 50k miles. I am sure the engine will last a long time if you keep doing your regular maintenance and replace parts. So far the most expensive things I have replaced for this car are upper/oil pan gasket, Vacuum pump, Injectors (Under Customer Care Package), Front Driveshaft (Under Customer Care Package), Transmission fluid mix and programming.
Currently I am at 65k miles and I am planning to keep the car until 100k miles for sure. It is a great car for sure but expensive to keep. Something I have to watch out for will be O2 sensors, valve stem seals, torque converter (vibration on the low end accelerations)
btw my car was produced in 07/2011
      11-13-2017, 09:54 AM   #7
JoeyBimX5din
Drives: 2011 BMX X5 Xdrive50i
I am at 105k, and it burns oil like its $3 a quart. Knock on wood other then that nothing too hateful. I have done a rear o2 sensor, and I currently have one bad coil pack.
I am doing 10k oil changes because I am doing a quart of oil every 500-1000 miles. If I the low end of that is because one time I was using Castrol 5w-20 when I saw the 500 mile oil usage. I have transitioned to 15w-50 Mobile 1. It is cheaper when I can buy the 5 gallon jugs for $26, vs the $10 per quart on the Castrol synthetic oil. It has also held in the motor a little better, so the oil usage may be a combination of PCV usage, and valve seal usage.
2011 BMX X5 Xdrive50i - 127K - No muffler, BMS Stage 1
2005 Jeep Grand Cherokee 5.7L V8-Her stock DD
1995 Ford Thunderbird 4.6 V8 LX - A bunch of mods BMW guys don't care about
1995 BMW 540i6 - H&R Lowering Springs, Bilstein's, Racing Dynamics Bars, Catback, Short shifter
      12-01-2017, 03:43 AM   #8
Bmwlover x
25
Drives: X6
Do not use 15w50. Use only 0w40. 5w30 or 5w40. 15w40 is not approved for bmws.
      12-03-2017, 05:41 AM   #9
JoeyBimX5din
The M's run 10/60, so we will see what happens with 15w50. I have had it in the truck for a good bit of time now.
      12-22-2017, 08:58 AM   #10
godmans
17
Drives: 135i / 335i / X6M
the higher weights were designed for the high revs 'M' NA motors...
tons of info on F10 M5 board
stick with the user manual recommended BMW LL01 0w40, 5w40
