      07-02-2014, 02:32 PM   #1
GeloCH
Switzerland
19
Drives: X5 30d M Sport, Space Grey
Tyre Pressure
Hi there.. Just got the "check tyre pressure" instruction.. what tyre pressure should i run? i have the 469 mixed... i remember the front and rear had the same
pressure, but should they be different? (usually 3 passengers)
Many thanks
      07-02-2014, 02:40 PM   #2
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
I discussed this in detail in this thread with a fellow member who had very high tire pressure/noise vibration: http://f15.bimmerpost.com/forums/sho...=tire+pressure
Front: 35-36
Rear: 42-44
That's for 21" tires, but is close to stock values for almost all tire sizes if you look on the driver side door - it should have some numbers there. My front are 35 and rear are 42 for my 22" tires.
As long as you you stay within that range, you're good.
      07-02-2014, 04:49 PM   #3
kanate
Drives: 2014 X5 xDrive35d
I don't know the tire size for 469 mixed but you can check the recommended pressure in our car's manual. Look at page 212-216.
Here's link to download owner's manual:
http://www.bmwusa.com/standard/content/owner/dgh.aspx
      07-03-2014, 12:09 AM   #4
phantomac2
Germany
Drives: BMW F15 (KS81)
There's a sticker in the frame of the driver's door showing all the recommended pressures.
      07-03-2014, 12:15 AM   #5
phantomac2
Germany
Here's a picture from my F15's sticker:
      07-03-2014, 10:22 AM   #6
GeloCH
Switzerland
19
Many thanks everyone..
The sticker on mine is a bit different, maybe because of engine size? so i guess i should put 2.2 in front (275/40 R20) and 2.4 in the rear (315/35/ R20). I wonder why it wasn't set that way from the dealer.. I've only got around 1,300 km on it and the tyre pressure warning comes up on the HUD and dashboard. Has anyone had the same?
      07-03-2014, 10:38 AM   #7
phantomac2
Germany
Yeah, the sticker's contents depend on the car's engine.
Do the following: refill the tyres to the recommended values, reset the tyre pressure system via the menu and wait.
If you get a tyre pressure warning again and one of the tyres has lost a significant amount of pressure, the tyre might be damaged - or, less costly - the tyre's valve.
