07-02-2014, 11:05 PM | #1 |
Rep 127
Removal of Lower Tail Gate - stumped...
I need to replace my lower tailgate (someone hit me with no license or insurance)...
I am having a tough time removing the plastic trim on the inside and top (when closed). Can anyone assist or point me in the right direction? Thanks in advance, Matthew |
07-03-2014, 12:27 AM | #2 |
Rep 18,713
@mattbar1,
Here is the parts diagram. There are about 5 screws (#10) on the bottom that is holding the plastic piece and maybe couple screw on the top (#14). I personally never take it apart yet. I did the top tailgate one already. Good luck.
07-03-2014, 06:36 AM | #3 |
Rep 127
Thanks r33,
The diagram helps! #9 and #13 are "clipped" together. No matter which way I pull or push, they do not want to snap apart. I can't figure out how they separate. I feel like any more force something will crack. Side note: Why did you take the top apart? Anyone, else have any insight? The older models seem to be very similar if anyone has done one of those. |
07-03-2014, 08:55 AM | #4 | |
Rep 18,713
Regarding the top part, I was bored at the office and just feel like doing something to the car.
07-03-2014, 10:12 AM | #6 |
Rep 1,547
That's the problem with some of these plastic clips...you never know how hard to pull / push before they might break.
07-03-2014, 10:14 AM | #7 | |
Rep 127
07-03-2014, 03:49 PM | #8 | |
Rep 18,713
I tried to pull it gently, but it didn't budge, give it a little force, some clip snapped. Haha. So I was like, screw it. Got it all apart and found out the replacement piece is costing me $20. Not bad. There is 2 #2 that is holding the center #13 by the latch mechanism. Maybe you can try break that loose first, then pull #13 and #9 all together. I looked at the clip and it seems like impossible to undo it without having them pulled off together, because they are hidden and unreachable. I assembled mine all together again and it seems unnoticeable, but I am going to replace them anyway. I hope you don't break yours, because based on my vendor, it is only 1 in the US (which I am getting) and 0 in Germany. Good luck.
07-03-2014, 07:53 PM | #9 | |
Rep 127
Oh man! You definitely didn't have to do that! I was about to report on my progress and saw your reply. I was able to get them apart, I pried the two pieces apart as much as possible. I was able to get a flashlight and one eyeball in there. I saw the first clip. I used a long (9 inch) screw driver to release the first clip, and started working my way down undoing each one. Manage to not break any, even after they started to clip back together when I was half way to the other side. A side note. I am having to replace the rear bumper cover as well. The dealership here ordered and sold us the wrong bumper. Although it is the shape of the 2014 M Sport bumper, it has no holes or receiving clips for the 4 backup sensors. The dealership tried to tell us that we have to drill the holes. Finally they admitted they ordered the wrong one. This is deceiving because even on realoem.com they show both X5 bumper styles without the holes for the bumpers. We should pay very close attention whenever we need work done, I am afraid body shops, dealerships, etc are going to try an cut lots of corners. Here is the realoem URL: http://www.realoem.com/bmw/showparts...46&hg=51&fg=17 |
07-03-2014, 07:55 PM | #10 | |
Rep 127
One more observation: I think I need to learn to relax a bit from you, I am stressed about my vehicle being damaged and you seem to be cool with a lesson learned...and oh well, I'll just replace the part... |
07-03-2014, 07:59 PM | #11 |
Rep 18,713
02-08-2019, 03:19 AM | #12 | |
Rep 41
Drives: BMW X5 45e -20, 225xe -16
Do I need to remove the plastic part inside and then just screw it out? many thanks for help BR, Ville |
02-08-2019, 08:06 PM | #13 | |
Rep 2,388
Step 2: https://www.newtis.info/tisv2/a/en/f...hts/1VnXUUGi5F Step 3: https://www.newtis.info/tisv2/a/en/f...hts/1VnXdB9VEk Step 4: https://www.newtis.info/tisv2/a/en/f...hts/1VnXSmwI7L P.S. Somebody need to make BMW tsi link a sticky |
