08-31-2021, 05:04 PM | #1 |
Rep 110
Water pump and spark plugs replacement
Guys, got the overheated problem, pulled over right away - OBD code - U019F, dealership quoted:
- Water Pump replace - $1553.36 - Spark Plugs replace - $1049.70 - Replace torn oxidized group strap at left rear of muffler - $129.48 Seems like a bit to much? Should I find some shop? Any recommendations in north Illinois area? Thanks in advance. |
08-31-2021, 05:50 PM | #2 |
Rep 1,497
I can only chime in on the spark plugs. I think I paid around $450 for OEM plugs + install at my indy shop. They only charge $85/hour and I'm sure BMW is north of $120/hr now.
08-31-2021, 05:59 PM | #3 |
Rep 110
Shoot, I figured that $1k is too much, but that's what I've got in the quote... May ask SA again about what they mean by $1k to replace plugs... ;-)
Also, water pump - on FCP Euro I see OEM set (pump, thermostat + coolant) is $700, so they charge what 250 per hour? Last edited by aschmidt; 08-31-2021 at 07:30 PM.. |
08-31-2021, 06:39 PM | #4 | |
Rep 97
2018 X5 35i
08-31-2021, 06:52 PM | #5 |
Rep 110
Don’t know about spark plugs - I think they mentioned misfires or something like that - I’ll ask again.
Water pump - I need a lift right? That coolant flush is difficult without a lift imho based on the videos… I don’t mind doing myself just not sure how to flush it on a driveway |
08-31-2021, 07:14 PM | #7 | |
Rep 1,697
Drives: 2014 428i and 2018 X5
I don't know how handy you are, but you can get the plug kit from FCP for maybe $160 and do it yourself in about an hour.
08-31-2021, 07:17 PM | #8 |
Rep 110
Got it, yea I’m all up for it to do sparks - did breaks just recently, thanks.
I could not find f15 n55 water pump replacement DYI… anybody has a link to a good video? Last edited by aschmidt; 08-31-2021 at 07:23 PM.. |
08-31-2021, 07:21 PM | #9 |
Rep 1,697
Regarding a water pump, yes you will need either jackstands or a lift as it can only be removed from underneath the car
08-31-2021, 07:24 PM | #10 |
Rep 110
Thanks got it, we’ll I guess I might do at an Indy shop rather… thanks anyway. Seems not difficult just a pain to snug under a car and flush all that and then bleed correctly…
08-31-2021, 07:44 PM | #11 | |
Rep 7,528
08-31-2021, 07:48 PM | #12 | |
Rep 110
08-31-2021, 07:55 PM | #14 | |
Rep 1,697
I just did both coils and plugs at 60,000. Probably didn't need to, but we bought the car used and I wanted to start as fresh as possible.
08-31-2021, 08:06 PM | #15 | |
Rep 110
So I need both spark plugs and coils correct? |
08-31-2021, 08:14 PM | #16 |
Rep 1,697
33k? Stick with the plugs first. But honestly you should get a second opinion or at least buy your own code reader. That way you can verify yourself if you need plugs, as 33k is way to early.
ggunn9160.00 |
08-31-2021, 08:17 PM | #17 |
Rep 297
Wow, that's low miles for a water pump to fail.
Personally, I wouldn't change just one coil and I wouldn't change plugs only and not do coils. I do my own work and would rather do both plugs and coils while everything is apart and I'm already dirty and sweaty. It would feel like double the work doing plugs only then coils later. |
08-31-2021, 08:27 PM | #18 |
Rep 110
Yes, but let me say first that this F15 was a troublesome from the beginning - at 20k I got engine replacement under warranty, and now thinking to try to prevent any chances to further damage with failed pump replace plugs and coils at once. But I’m not sure when engine was replaced they did also plugs - I’ve asked SA about pump and he said it’s original. So I doubt that coils will last.
So I need basically torque wrench and custom socket right for plugs? |
08-31-2021, 09:14 PM | #19 |
Rep 179
For the n55 it's easier to take the fan out and you can get it out from the top
09-02-2021, 02:14 PM | #20 | |
Rep 110
Thanks for your feedback about spark plugs and coils… which torque wrench do you use for spark plugs? |
09-02-2021, 02:17 PM | #21 | |
Rep 1,697
This is the socket I use ARES 11000 - 14mm Thin Wall Magnetic Swivel Spark Plug Socket - 3/8-Inch Drive 12-Point Spark Plug Socket - Walls 2mm Thinner Than Standard Spark Plug Sockets https://smile.amazon.com/dp/B07RR84R...UTF8&psc=1
09-02-2021, 05:37 PM | #22 |
Rep 297
I've never used a torque wrench when installing plugs, just do it by feel. I just don't trust torque wrenches (well, not the torque wrenches in my budget) when bolting steel into aluminum.
