Go Back   BMW X5 and X6 Forum (F15/F16) > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      11-03-2017, 11:25 AM   #1
mirob
mirob's Avatar
Drives: M3CX
Updated: Fire hazard: BMW recalls 1.4M vehicles due to risk of under-hood fires
BIMMERPOST
     Featured on BIMMERPOST.com
This may be useful to some.
One of my friends has an N54 335i. He called BMWNA and told them that he's worried that the car would catch fire in the garage and set the house on fire. They were totally understanding and told him that there isn't a remedy for the problem yet (not really one in sight either).
However, they also told him to drop his vehicle off at the nearest dealer, they would contact the dealer and set everything up. The dealer would either put him in a loaner or a rental. So he did. He's in a rental now and up until they fix the issue. He's assuming that cars that are replaced with rentals will get fixed first since it's costing BMW extra money. Makes sense to me.
Just wanted to give the guys with the affected vehicles a heads up.
DETROIT — BMW is recalling more than 1.4 million cars and SUVs in two U.S. recalls due to the risk of fires under the hood.
A spokesman for the German automaker says the risk of fire is very low in both cases, but the vehicles should say outside "in an abundance of caution." In both recalls, repairs are expected to start on Dec. 18.
The largest of the recalls covers over 740,000 328i, 328xi, 328i xDrive, 525i, 525xi, 528i, 528xi, 530i, 530xi, X3 3.0si, X3 xDrive30i, X5 xDrive30i, Z4 3.0i, Z4 3.0si and Z4 sDrive30i vehicles from 2007-2011. Also included is the 2008-2011 128i. All have 6-Cylinder engines.
Documents posted Friday by the U.S. National Highway Traffic Safety Administration show that a heater for the positive crankcase ventilation valve can overheat and cause the valve to melt, increasing the risk of a fire even when the vehicle is not in use. No injuries have been reported. Dealers will replace the heater.
The heater is designed to prevent the valve from freezing in cold temperatures, BMW spokesman Hector Arellano-Belloc said. But irregularities in manufacturing can cause corrosion can lead to overheating.
The other recall covers nearly 673,000 cars including the 323i, 325i, 325xi, 328i, 328xi, 330i, 330xi, 335i, 335xi and M3 from the 2006-2011 model years. Also covered are the 2007-2011 328i xDrive, 335i xDrive and 335is, and the 2009-2011 335d.
Wiring for the heating and air conditioning system can overheat and cause connectors to melt, also increasing the fire risk, even when vehicles are unattended. Four drivers reported injuries. BMW says a wiring connection can corrode and in rare cases cause fires.
Dealers will replace the wiring and connectors.
The recalls total about 1.4 million vehicles, but some are included in both, BMW said.
https://www.usatoday.com/story/money...res/828690001/
NHTSA document/report for affected 3-series vehicles in HVAC wiring recall (includes production date ranges:
https://static.nhtsa.gov/odi/rcl/201...7V676-9625.PDF
Other document/report for affected vehicles in PCV heater recall:
https://static.nhtsa.gov/odi/rcl/201...7V683-7475.pdf
      11-03-2017, 02:55 PM   #2
TooFan328i
224
Drives: 2016 YMB M3
BMW recalling a million vehicles
Just read this:
https://www.reuters.com/article/us-b...-idUSKBN1D31MM
      11-03-2017, 03:04 PM   #3
mkoesel
Moderator
Drives: No BMW for now
Interesting that USA Today misrepresented the fact that, since there is overlap between the two recalls, only a million distinct vehicles are actually affected. Of course, there is nevertheless 1.4 million issues to address with said vehicles, so sure, that's important to report too.
      11-03-2017, 10:43 PM   #4
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
Drives: 2018 Audi S5 Coupe
DETROIT (AP) — BMW is recalling more than 1.4 million cars and SUVs in two U.S. recalls due to the risk of fires under the hood.
The biggest recall includes over 740,000 328i, 328xi, 328i xDrive, 525i, 525xi, 528i, 528xi, 530i, 530xi, X3 3.0si, X3 xDrive30i, X5 xDrive30i, Z4 3.0i, Z4 3.0si and Z4 sDrive30i vehicles from 2007-2011. Also included is the 2008-2011 128i.
The second recall covers nearly 673,000 cars including the 323i, 325i, 325xi, 328i, 328xi, 330i, 330xi, 335i, 335xi and M3 from the 2006-2011 model years. Also covered are the 2007-2011 328i xDrive, 335i xDrive and 335is, and the 2009-2011 335d.
Dealers will replace the wiring and connectors. Both recalls begin Dec. 18.
http://kron4.com/ap/bmw-recalls-1-4m...er-hood-fires/
      11-04-2017, 07:19 AM   #5
RickFLM4
RickFLM4's Avatar
Drives: M4
Maybe good to have this link in this thread:
https://www.bmwusa.com/safety-recalls.html
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
Dackelone10538.50
      11-06-2017, 06:35 AM   #6
DrtyJrze
DrtyJrze's Avatar
707
Drives: 2017 M3
So basically if you're driving a 7-12 year old car it may start having electrical problems.
Is this really breaking news? Glad they're having a recall, but I wouldn't bad mouth BMW for this one.
      11-06-2017, 06:53 AM   #7
balloonsalesman
balloonsalesman's Avatar
Drives: 2011 1M BSM
Wondering if the 1M is involved? Basically same engine as many of the cars included.
1M Tex240.00
      11-06-2017, 07:01 AM   #8
Sge92x
Drives: E92 328i xdrive
I wonder what would be different for the 2012 e92 328i xdrive and would it be on the recall next
      11-06-2017, 07:21 AM   #9
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Wow that headline sounds so bad. 1.4 million vehicles recalled due to risk of under hood fire.
Then you read the story and these vehicles are 7 - 10 years old and only now showing a problem? This is probably more of a precautionary measure by BMW than an issue.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      11-06-2017, 07:40 AM   #10
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by balloonsalesman View Post
Wondering if the 1M I'm involved? Basically same engine as many of the cars included.
I'm sort of surprised it isn't. It appears that no 135/1M/z435is are included but oddly the 335 from the same period is included in the second recall.
      11-06-2017, 08:11 AM   #11
norsairius
Foodie and Gearhead
norsairius's Avatar
Drives: 2011 335i xDrive Sedan
NHTSA document/report for affected 3-series vehicles in HVAC wiring recall (includes production date ranges): https://static.nhtsa.gov/odi/rcl/201...7V676-9625.PDF
Other document/report for affected vehicles in PCV heater recall: https://static.nhtsa.gov/odi/rcl/201...7V683-7475.pdf
2011 335i xDrive Sedan, Deep Sea Blue w/Oyster Interior
      11-06-2017, 08:33 AM   #12
kevinlevrone
Drives: 335i
Why not Europe too ? Do you really think they use different wiring in Europe ? No, its just that the EU does not have the necessary power to force BMW to do this recall.
      11-06-2017, 08:46 AM   #13
XxGhostxX
Drives: 2000 M5, 2011 335IS
I looked up my 2011 335IS and it says I don't have a recall but seems as I am in the date range. Any idea on if mine still might be affected?
      11-06-2017, 08:56 AM   #14
adc
Drives: 2018 F80 M3 ED
If your 7 year old car caught fire sitting in your garage and caused your house to burn down perhaps you would be less forgiving.
That’s exactly a scenario that could happen, and BMW wants none of that on their hands. These aren’t electrical gremlins, as in your AC only works if you jiggle the knob, this is serious and potentially life threatening.
It’s very good that BMW decided to own this issue and get it done right.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
Appreciate 8
Rupes1055.50
TBN54426.50
lab_rat394.50
      11-06-2017, 09:08 AM   #15
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
I wouldn't give them a pass either. And no, it's not normal for cars to have electrical issues after 7yrs that result in fire. lol
Appreciate 4
nis270r33.00
Rupes1055.50
      11-06-2017, 09:24 AM   #16
Mtl128_25
Drives: 328i 2008
Guys,
I am not a 100% sure but earlier this year i had to change the evaporator on my 2008 328i coupe. While they were doing this change they noticed that «*something a part*» had completely melted and i had to change this piece. It was an extra 500$. All this was done at the dealer. If it turns out related to this recall, would bmw reimburse me? Im in Canada.
I can eventually look in my receipt and give you guys more details on prt numbers and all if it helps.
Thanks
      11-06-2017, 09:28 AM   #17
phoenixbmwlife
The emphasis is on if. Which is why I will reiterate what I said. I believe this is more of a precaution. It's been 10 years for some of these cars with no issues. If it happens in its 30th year of existence it's an issue for BMW which is why I believe they recalled it. Don't misconstrue what I said.
Follow me on Insta
      11-06-2017, 09:29 AM   #18
Eddien123
Drives: F30 335 6MT
Interesting... will probably get something in the mail soon.
      11-06-2017, 09:32 AM   #19
LemonOne
LemonOne's Avatar
Drives: ///Most Powerful Letter
2006 M3 (E46) and 2007-8 M3 (E92) are both recalled?? I'm a bit confused.
It says Model Year so both the E46s and E92s are effected?
      11-06-2017, 09:47 AM   #20
Em/1
Em/1's Avatar
Drives: 2011 1M VO
2019 VW GTI SE  [0.00]
2020 Tesla M3P  [0.00]
2011 BMW 1M  [0.00]
Seems Mike (Roundel tech writer) is right again when he complains about the harness being reduced to practically copper vapor to save money and a little weight.
1M Tex240.00
F32Fleet3571.50
      11-06-2017, 10:36 AM   #21
secretanchitman
Drives: 2020 F82 M4 6MT
Looks like my E92 335i is affected. Fine with me as long as it gets repaired in a timely manner this time!
When should we expect parts to arrive to fix our cars?
      11-06-2017, 10:42 AM   #22
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
The gauge of the wire is not the cause of the issue, is the connection is slightly loose and causes heat buildup. Water ingress into the blower motor from improper repairs, namely the windshield replacement, makes the situation worse.
