      10-14-2017, 01:50 PM   #23
turboawd
1635
Drives: 2015 X5 35i
Originally Posted by buckeyewalt View Post
Got my vehicle back from the dealership and I did duplicate the issue with the mechanic riding with me.
They replaced the transfer case unit., AT-Auxiliary transmission, and the transmission bearing. That fixed it. No more tugging/lugging just a nice smooth and powerful acceleration.
what is "auxiliary trasmission"?
      10-16-2017, 11:17 PM   #24
buckeyewalt
Drives: 2014 X5 50i
Just wrote what they put on the work order. I assume it's the transfer case itself.
      10-17-2017, 12:30 AM   #25
kanvas
kanvas's Avatar
Drives: V8
Ah forgot to update you all on this. I got it fixed a while ago but forget what the diagnosis repair was. I'll check the paper someday.
2014 X5 xDrive50i
      10-30-2017, 07:36 PM   #26
kanvas
kanvas's Avatar
Drives: V8
This is on the dealership service maintenance papers:
"FAULTS 14001, 140010, 140701, 140710 FOR CYLINDER 7 MISFIRE PRESENT. REMOVED IGNITION COIL 7 AND SPARK PLUGS. FOUND SPARK PLUG DRY AND SLIGHTLY FOULED."
In search for answers, I came across this from a Google search:
"The most likely cause is worn valve guide seals and/or guides, but worn rings and cylinders can also allow oil to enter the combustion chamber. Replacing the spark plug will temporarily cure the misfire problem, but, until the oil consumption problem is fixed, the engine will continue to foul plugs."
I know the 50i eats up oil like no other. Is there a relationship between this and spark plugs drying up?
2014 X5 xDrive50i
      10-31-2017, 03:47 AM   #27
DuSh
DuSh's Avatar
2113
Drives: F15 X5 50i
This confirms my suspicion that it's in fact a misfire (spark plug/coil) issue that is causing tugging/twitching and not a transmission related thing (at least half of cases)
      05-06-2018, 12:53 PM   #28
turboawd
1635
Drives: 2015 X5 35i
I getting what feels like a kick in the rear. Seems to happen under light acceleration around 2 to 3 gear.
Happened a couple times yesterday and worse today when I first started up and drove off.
Misfire perhaps? I do put in the cheap gas. Has that caught up with me now? Lol
      05-07-2018, 01:42 PM   #29
boyce89976
Drives: 2014 X5 5.0 M Sport
Found my old post:
I had a post on here about my vehicle shudder at part throttle that was progressively getting worse. I had it almost since I had the vehicle but they never found out what the cause was because it never threw out a code and was hard to duplicate. I took the vehicle in the other day because of a scheduled brake fluid change and mentioned this again. When I picked up the vehicle, they told me that there is a bulletin out for this issue SIB 12 23 16 (.4) in which they performed a vehicle coding and programming for the fix. FINALLY!!!!
Then someone said that they couldn't find the SIB so I looked again:
I re-read my service write up and that's the correct SIB 12 23 16 0 .90
Hope this helps.
I had this on a Honda Pilot (2012) and it got so bad I sold it. Honda did a bunch of stuff to try to fix it... loosened the engine and tranny mounts - drive it around a bit - and re-torque them, replaced the fluid 3 times, reprogramming, to name three. I suspect it had the same issue as described in this SIB. Glad you got it fixed.
I can feel a slight shudder in my 2014 X5, but it's intermittent and not repeatable. Only really happens when slightly letting off the throttle.
      05-07-2018, 01:59 PM   #30
Florida-X3
Drives: '23 X3 x30i / '12 Infiniti M37
I have something that feels like old fashioned "wheel hop" (but milder) during hard acceleration when I get on it.
      05-07-2018, 03:51 PM   #31
LocksmithNick
LocksmithNick's Avatar
Drives: BMW X5 M Sport - G05
Why would you not use premium gas on a BMW?
      05-07-2018, 11:44 PM   #32
turboawd
1635
Drives: 2015 X5 35i
i usually dont drive hard, so no real load on the engine. plus premium is so much more!
      06-23-2022, 01:11 AM   #33
bhkj9999
Drives: X5 xDrive50i
Any new updates?
Mine is tugging, too. When it's on 2nd(10-15mph) or 3rd(15-20mph) gear(depends on driving mode), I noticed it always chooses to downshift rather than stay in the higher gear. Sometimes it feels like the manual car when you apply the gas paddle a little bit, it will slow down a bit(with rpm going up) and then accelerate. I had to keep my foot on the gas paddle, or it felt like somebody dragging me back...
Sometimes, I don't even need to apply the brake to stop when I approach a traffic light with my speed at 20mph or 15mph, it will automatically drop down to 5mph and hold there.
Is that because x5 is too heavy to maintain the speed?
      07-28-2022, 02:02 PM   #34
Edwardsc1
Edwardsc1's Avatar
Drives: 2015 BMW X5 50i
2015 BMW X5 50i  [0.00]
These are BMW's, not Hondas. If you can't afford the gas, you should absolutely not be driving a BMW or any other performance vehicle.
2015 X5 50i - Current
2011 E92 M3 - Sold
2016 F30 340i - Sold
Search this Thread:
Advanced Search
