04-19-2016, 07:35 PM | #266 |
194
Rep 325
Need Help after retrofit
Hello, I'm trying to retrofit an 6WB instrument cluster in an F15 2013. My problem is that the 6WB cluster came from an F10 and the HUD is not working. I saw on clusters pin assigment that pin 10 from 6WB F15 is HUD power suply, but on F10 pin 10 is not used. So if I take wire from pin 10 and give it 12V from pin 2 from cluster , do you think it will work? Anything else is working OK.
So if you have any idea please let me know. Thank you. |
04-19-2016, 10:24 PM | #267 | |
Rep 3,990
04-19-2016, 10:35 PM | #268 |
Rep 40,883
04-19-2016, 10:37 PM | #269 |
Rep 3,990
04-19-2016, 10:40 PM | #270 |
Rep 40,883
04-19-2016, 10:43 PM | #271 |
Rep 3,990
05-04-2016, 01:13 AM | #272 |
194
Rep 325
Thank you for help, but the problem was cluster it self. The 6WB (I'm not sure about 6WA) for F15 F16 are different than F01 F10 F06 etc. For F15 and F16 there is a specific cluster. I changed cluster with one dedicated to F15/16 and everything worked.
For the moment I'm working to retrofit 6WA 6WB (from F10) to F30. 6WA it's on 95% done. |
10-21-2016, 09:52 AM | #273 |
Rep 10
Thank for the great guide.
I just put in a 6WB today on a 2017 F15. I love the look of the dash now. One thing I noticed, however, is that they HUD is now tilted a bit. I am wondering if when removing cables that I might have pulled too much on one of them and moved the HUD on accident? Any way to easily fix this? Also when detecting CAF for SWE I could not find a number that exactly matched the I-Level in the bottom right hand corner of E-Sys. Does anyone know why this might be or if I will have a big problem with this? Edit: The iDrive controls work today for rotation. They didn't work yesterday at all. Last edited by joder; 10-21-2016 at 12:19 PM.. |
monkiboy534.50 |
10-21-2016, 10:15 AM | #274 |
Rep 561
You should be able to fix this in the HUD settings using your iDrive.
10-21-2016, 12:18 PM | #275 |
Rep 10
11-01-2016, 10:58 AM | #276 |
Rep 67
Bump again
I found realoem's newest part number 62106841977 and a seller on eBay for $2,699.00!!!! http://www.ebay.com/itm/BMW-OEM-F15-...lX4txN&vxp=mtr Is this the real deal? Any chance someones shares a light about the newest display? |
11-26-2016, 12:50 PM | #277 | |
Rep 1
02-20-2017, 09:33 AM | #279 | |
Rep 674
Then I jumped into the new 5 Series and WOW that cluster is much more advance, its sharp and resolution is amazing. |
1230vani657.00 |
02-20-2017, 11:05 AM | #280 |
Rep 3,742
There is a 2015 CPO xDrive35i for sale in Atlanta with the 6WB digital cluster. I am kind of surprised that the leasee did you remove the cluster prior to lease turn in as he/she could have recouped some of his/her investment.
02-21-2017, 06:32 PM | #281 |
1152
Rep 2,426
Also new iDrive 6 display seems sharper as well, and the screen looks bigger and the touch screen is really easy to use.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
02-25-2017, 10:01 AM | #282 |
Rep 48
Just sat in the new 5 series and wow, what a cluster! Hope they create something to that level for us soon.
02-25-2017, 10:42 AM | #283 | |
Rep 2,711
