06-30-2015, 10:17 PM | #23 | |
Rep 114
2018 X5M, 2012 R8 GT, 2016 F80 M3, 2013 S4
06-30-2015, 10:22 PM | #24 | ||
Rep 114
I now have it wired up top near my mirror hard wired through the mirror ( I had someone install the wiring) It works great! definitely more effective than the V1
06-30-2015, 11:33 PM | #25 | |
Rep 128
I find that all 3 models of Escort GPS units that I owned (9500ix, Passport Max, Passport Max 2) offer about the same protection. Perhaps the newer units are supposedly better, but it's not necessary as I never got a ticket with the 9500ix over the few years that I had it. The main difference between 9500ix and Passport Max is the entire design of the unit is new, the display is multi-colored, but functionality wise it's pretty much the same. I find myself setting it up once initially and then never touch it again. Passport Max and Passport Max 2 are exactly the same except Passport Max 2 no longer needs the special chord and instead connects to your phone through bluetooth. I actually don't find the functionality useful as I never bother to open the app on my phone. I also don't find Escort Live useful. You're better off using Waze on your phone if you want crowd-sourced information. It all depends on if laser is used in your area. If it is then you do need to rely on crowd-sourced info. If I had to recommend a unit based on best value it's the 9500ix. You can probably get one on Ebay for quite cheap and it's going to serve its purpose which is to keep you from getting a radar ticket. I personally am pretty into gadgets so I do have the Passport 2 which is the latest and greatest, and that's fine as well, but it's more expensive and serves the same purpose. All of them are excellent, just make sure it has GPS. As far as mounting goes, I use Blendmount. For my X6 the correct mount is BMW-006. Blendmount actually offers a kit that allows you to tap into your mirror for power. That's not what I use though. I have my car audio installer direct-wire the radar detector. One problem if you decide to use Escort Live with the cord is you have to use that cord to power the detector, so you can't direct-wire or use a mirror-tap. |
07-03-2015, 10:29 AM | #27 |
Rep 1,547
Looks great man...I too usually prefer a de-badged look, but the contrast with the red is unique for sure. Nicely modded X5, well done.
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 Last edited by stewy604; 11-24-2015 at 09:33 AM.. |
10-20-2015, 11:33 AM | #28 |
Rep 114
[u2b]<iframe width="560" height="315" src="https://www.youtube.com/embed/5jUsT9fCqtE" frameborder="0" allowfullscreen></iframe>[/u2b]
10-20-2015, 11:47 AM | #30 |
Rep 114
11-11-2015, 10:37 PM | #34 |
Rep 502
What size of QTP cut outs did you use? I want to look into this!
Sunset Orange G20 M340i
PAST F80 LCI/M3/AW FBO BM3 Cary Tuned Meth/Pure Stage 2 F36 CB 435i FBO F15 GS X5 50i Tune F10 AW 550i Loaded/Tune/M5 Exhaust |
11-11-2015, 10:41 PM | #35 | |
Rep 114
i went with the 3.5 inch.. but as i was told each pipe is a different size so they had to fabricate their own pipe to accommodate
11-11-2015, 11:25 PM | #37 | |
Rep 114
11-13-2015, 09:48 AM | #38 | |
Rep 144
11-13-2015, 02:15 PM | #39 |
Rep 114
Plasti Dip and then used there gloss spray
11-24-2015, 01:06 AM | #40 | ||
Rep 502
01-14-2016, 01:05 PM | #42 |
Rep 1,547
I think he bumped the fronts up to 285s, from the OE 275/40/20? Rears should be 315/35/20.
05-24-2019, 03:16 PM | #44 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
do you ever have any issues with your valves leaking? in this pic looks like they don't seal all the way, so I'm wondering when your run your valves closed can you hear any leaks from it? thanks
Tags |
bmw x5, exhaust cut outs |
