12-30-2019, 11:13 AM | #1 |
Rep 1,859
Drives: 23' X7 40i M Sport
Apologies for the new thread. I felt my pain and suffering warranted a new analysis on where things can go wrong. I want your feedback...
Spent Saturday re-doing my exhaust tips for the 3rd time in 1 year. I had spent countless hours researching the perfect prep work and recipe for success. I am truly anal about any mod and felt I finally did it right until my project folded like a lawn chair. For such a trivial task I can't fathom what I am doing wrong...I honestly feel like less of a man. 1) After proper cleaning, sanded with 320 grit 2) Masked up the bumper with newspaper and painters tape (this is always the most labor-some part) 3) Applied primer, paint and clear coat. Let the primer dry 2 hours before moving forward with the paint and clear coat. All applications of paint were completed 10 minutes apart. a) 2 coats of VHT Self-Etching Primer b) 4 coats of VHT Black Engine Enamel c) 3 coats of VHT Clear Coat 4) Let dry for 24 hours - Boom! Everything was perfect. Now on to the recommended curing process for "on-vehicle". I can't decide if this was done too soon, executed poorly or completely unnecessary. 5) Started curing process as directed by VHT a) Idle for 10 min b) Cool for 20 min c) Idle for 20 min d) Cool for 20 min e) Drive for 30 min - this is was literally the last step and where everything fell apart like a Greek tragedy...See last photo for disaster... My initial thoughts for where this may have gone wrong. Either one of two things happened... 1) Too much condensation remained in the tailpipes after washing the car. During the curing process that may have been executed too soon, moisture built up in the finish that wasn't actually dried (even after 24 hours). When I drove the car in step 5e, I pushed the car thinking I needed to get the tips hot where it essentially steamed the moisture and boiled off the paint... 2) I'm a tool and can't do a damn thing right...
12-30-2019, 12:07 PM | #2 |
that's what SHE said!
75
Rep 1,163
In the last pic did it just flake off or is there a hole there? Wouldn't it just soot over anyway, not sure you really need to fret over it.
Otherwise, I think it looks pretty good! For some reason I also like the look of the matte primer.
12-30-2019, 03:01 PM | #3 |
Rep 1,859
The paint literally melted back...
12-30-2019, 04:33 PM | #4 |
Rep 73
I hate when something like this goes like this
Is it possible that that spot is the low spot and too much material ended up there for too thick a coat of something? Am I just not seeing it or is the primer not heat resistant rated? |
12-30-2019, 05:17 PM | #5 | |
Rep 1,859
I assume the primer is heat rated since it is a VHT product but I could be wrong.
12-30-2019, 09:01 PM | #6 |
Rep 142
It might be the paint itself. I used the roll bar and chassis paint as below. It's rated lower temp than yours. Also I did not prime or sand. Been on for over a year without issues through car washes etc.
-this paint is also a primer corrosion and weather resistant which I see on your bottles don't say that. So hopefully that's a quick solution |
P111575.00 |
12-30-2019, 09:48 PM | #7 |
Rep 18,724
I have been using the roll bar & chassis VHT paint.
None of my customers been having issue with them. But it could also because you didn't let it fully cure and you drive the car already. When I paint them, I let it sit 24 hours before shipping or installation.
12-31-2019, 07:17 AM | #8 |
Rep 648
I'm casting a vote blaming the primer. Workmanship looks top notch otherwise.
Just because it is a VHT product, doesn't mean it is heat rated, ...anymore. Brand started out with only high heat products, but the primer is part of their "Specialty Products" line that also includes vinyl and fiberglass paint, it's not part of the "High Temperature" line. Looks to me like primer started melting, likely bubbling, putting pressure on the harder "high temperature" paint, leaving it looking like a chunk of paint broke off. I would sand down the damaged area, and paint it with the high heat paint only, see it it sticks for a while. (or contact VHT customer support and ask them for advice) Good luck! |
classic_erik2810.00 |
12-31-2019, 07:57 AM | #9 | |
Rep 1,859
12-31-2019, 05:00 PM | #10 |
Rep 1,859
Ok I'm coming back off the ledge. Doesn't look too bad after all.
12-31-2019, 05:44 PM | #11 |
231
Rep 369
Mod complete, will see how long it's gonna last lol
Current
12-31-2019, 05:48 PM | #12 |
Rep 1,859
Looks great!!!!
12-31-2019, 06:04 PM | #14 |
Rep 1,859
Wish I could my friend. 50i owner here.
12-31-2019, 06:07 PM | #15 |
231
Rep 369
That would be the best but unfortunately they are not removable.
Current
12-31-2019, 07:21 PM | #16 |
Rep 1,915
12-31-2019, 08:00 PM | #17 |
231
Rep 369
That's for sure the option but if I cut those I would probably weld back quad exhaust.
Current
07-27-2021, 01:20 PM | #19 |
Rep 1,859
Pro-tip: run!
parthpatel1556.50 |
07-27-2021, 01:50 PM | #20 |
Rep 296
07-27-2021, 01:52 PM | #21 |
Rep 1,859
Zero issues driving without the tips.
parthpatel1556.50 |
10-19-2021, 02:17 PM | #22 |
Rep 1,859
I can not escape this cold dark hell.
Take a look at this gloss black powdercoat finish. Less than 1 year and it's failed. I spoke with another speciality powdercoat shop in Allston who says they can chemically strip down back to chrome and re-powdercoat in a satin black ceramic that will resist the high temps that most likely caused this issue. I suppose this is the reason you see satin black finishes on tips from most exhaust manufacturers…live and learn. The saga continues. Will report back…
ggunn9160.00 |
