      12-13-2017, 01:11 PM   #3851
shawnsheridan
shawnsheridan's Avatar
Originally Posted by wwanthony View Post
Hey Shawn,
Do I read the FA (assuming the one I have modified), after the Activate, or go straight to the ECU step.
Load and Activate original FA. I have no way of knowing if you have Original FA or Modified FA stored in car VCM, which is what Read FA pulls.
      12-13-2017, 06:02 PM   #3852
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Hey Shawn,
If you wrote modified FA to VCM, you need to reverse steps to change back to factory.
If not, then you could read and activate.
      12-14-2017, 11:42 AM   #3853
wwanthony
Drives: 2015 X5 XDrive 35i
To follow up. I was trying to get back to the factory defaults. I activated the FA (without reading) and VO coded and got what I wanted. All my coding disappeared. Thanks for the help.
      12-14-2017, 12:09 PM   #3854
shawnsheridan
      12-21-2017, 09:36 AM   #3855
wordsworth03
Drives: na
Can someone send me the link for the latest software? Thanks in advance!
      12-21-2017, 09:50 AM   #3856
shawnsheridan
PM sent.
      12-22-2017, 08:51 PM   #3857
wordsworth03
Drives: na
Originally Posted by shawnsheridan View Post
PM sent.
Thank you!
      12-23-2017, 01:27 PM   #3858
Crisp
Crisp's Avatar
Albania
420
Drives: F95 X5M
PM sent.
Would you mind giving me an early Christmas present as well by sharing the latest E-Sys version?
Thank you in advance.
Current F95 X5M; E60 M5 6spd; Mclaren 570s; Aston Martin Vantage; Ferrari FF
      12-23-2017, 01:32 PM   #3859
shawnsheridan
PM sent.
      12-23-2017, 02:42 PM   #3860
leasehackr
Drives: X5, 530e
PM sent.
Shawn- could you pls. PM me latest sw? Picked up 40e and 530e over the weekend.
Also Is this correct?
For 40e - F15 series chassis. Connection rel="ugc" target=F25
For 530e - G30 series chassis. Connection rel="ugc" target=?
      12-23-2017, 02:44 PM   #3861
shawnsheridan
For 40e - F15 series chassis. Connection rel="" target=F25
For 530e - G30 series chassis. Connection rel="" target=?
PM sent.
G30 uses S15A Connection Target.
      12-23-2017, 03:08 PM   #3862
leasehackr
Drives: X5, 530e
PM sent.
      12-23-2017, 05:14 PM   #3863
dondiego
Drives: 2017 X5 40e
Could I get a link to the latest version as well? Looking to code my 2017 40e.
      12-23-2017, 08:42 PM   #3864
shawnsheridan
PM sent.
      12-26-2017, 02:42 PM   #3865
wordsworth03
Drives: na
Shawn, could I get a link for the cheat codes? Thanks in advance
      12-26-2017, 02:51 PM   #3866
shawnsheridan
Cheats are built into E-Sys Launcher.
      12-26-2017, 02:57 PM   #3867
wordsworth03
Drives: na
Ah, thanks. Sorry, I’m new to cheats and just manually coded before. Do I connect to the vehicle, read/activate FA, then go to the cheat codes and apply? And then code FDL? Sorry for the dumb questions but I haven’t found a straightforward guide on how to use them.
      12-26-2017, 03:10 PM   #3868
shawnsheridan
http://www.bimmerfest.com/forums/sho...d.php?t=874588
      12-26-2017, 04:01 PM   #3869
wordsworth03
Drives: na
Thanks, Shawn. So my car has an unmapped HKFM2 file. I am trying to program the trunklid to close with the remote. I saw an earlier post stating that I can directly compare an older HKFM to my newer one since the positions should be the same. Is there any way to download an older HKFM file to compare the position to my current one?
      12-26-2017, 04:09 PM   #3870
tedt21
Drives: 2015 x5 2019 33i
Can I please get links to the latest software I need to code my 2015 X5? Also does anyone have links for the latest ISTD D and P?
      12-26-2017, 04:11 PM   #3871
shawnsheridan
PM sent.
      12-26-2017, 04:15 PM   #3872
laser21
Drives: i4 M50
Can I please get links to the latest software I need to code my 2015 X5? Also does anyone have links for the latest ISTA D and P?
