12-26-2017, 04:17 PM | #3873 |
Rep 40,786
I cannot help with ISTA. PM sent.
12-26-2017, 09:30 PM | #3874 | |
Rep 40,786
12-26-2017, 09:59 PM | #3875 |
Rep 120
12-26-2017, 10:01 PM | #3876 |
Rep 40,786
What is name of HKFM2 CAFD that is not mapped?
12-27-2017, 12:38 AM | #3877 |
Rep 8,364
12-27-2017, 10:25 AM | #3878 |
Rep 120
12-27-2017, 12:28 PM | #3879 |
Rep 8,364
wordsworth0324.00 |
12-27-2017, 12:39 PM | #3880 |
Rep 120
12-27-2017, 04:34 PM | #3881 |
Rep 8,364
12-28-2017, 09:26 AM | #3882 |
Rep 3
question about activation of the RDC on F 15 30dx build 2016 or switching from RPA to RDC. Installed wheels' monitoring modules, last model. I did following coding:
HU_NBT > 3001 > RDC > activ HU_NBT > 3001 RDC_SAFETY > activ HU_NBT > 3001 RPA > nicht_aktiv HU_NBT > 3001 RDC_FORTSCHRITTSANZEIGE > activ HU_NBT > 3001 REIFENUEBERWACHUNG_RDC_RPA > rdc HU_NBT > 3001 RDC_DRUCK_TEMP > druck druck_und_temperatur The problem that in spite on long driving, more then three weeks, and several restarting of the RDC wia idrive menu, value of the pressure and temperature not appear yet. All the time there is notice on the monitor: "Calculating of the pressure and temperature". Also what is a bit strange, cause I did same on my car f 15 25dx build 2016 and at the beginning appear notice "Initialization of the RDC system" with progress in %, then several days same notice "Calculating of the pressure and temperature". then values appear. On the car of my friend at the beginning appear "calculating" and was no any "Initialization". Please advise what should be coded additionally? |
12-29-2017, 09:56 PM | #3883 |
Rep 3
12-29-2017, 09:57 PM | #3884 |
Rep 40,786
Are you pressing and HOLDING the button, up to 20 seconds?
12-30-2017, 01:26 AM | #3885 |
Rep 8,364
12-31-2017, 07:48 PM | #3887 |
Rep 40,786
PM sent.
01-02-2018, 01:22 PM | #3888 |
Rep 120
So I just launched E-sys again and it’s acting weird. Launcher is asking me to set a new pin for a new token, and when I do, it keeps asking me over and over again to do the same and won’t open E-sys. I just used it last week without any issues. I uninstalled and re-installed all E-sys as well as Launcher. Anyone else ever run into this issue? I am running E-sys 3.27.1 and Launcher 2.0. Thanks
01-02-2018, 02:20 PM | #3889 | |
Rep 40,786
http://f30.bimmerpost.com/forums/sho...1&postcount=15 Now, you must use Launcher PRO 3.x. One needs to email Developer TokenMaster (fxx token master @gmail.com without the spaces), and then be patient after that.
01-02-2018, 02:27 PM | #3890 | |
Rep 120
01-03-2018, 03:45 AM | #3892 |
Rep 40,786
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-03-2018 at 06:49 AM.. |
KiLl3R|PL|123.50 |
01-03-2018, 02:36 PM | #3893 |
Rep 2,511
So to be clear- from 1/1/18 i can use E-Sys Launcher Premium only if i change system time prior to that date, or I can donate $50 and wait for Token Master to give me access to the E-Sys Launcher Pro. Did i get it right?
01-03-2018, 02:45 PM | #3894 | |
Rep 982
Quote from Shawn's above link: "So, you must get Launcher PRO 3.x, or play date games with your PC; however, the latter is not so easy as Launcher PREMIUM has built in logic to check for date manipulation, which is why people are having to resort to a Clean Windows Install, Date Change, then Launcher PREMIUM Install. If you are running Windows in a VM, maybe that is palatable, but if Windows is primary OS, it's simply not feasible." Also, the donation is to a Charity of your choice, not to the developer directly. |
