08-20-2017, 08:26 PM | #1 |
Rep 9
X5 (F15) How to shift into Neutral
Hi All,
How do you shift into neutral without starting the engine? On my E93 you push the start button without your foot on the brake and the ignition comes on then you put your foot on the brake then you can shift into neutral. I tried this procedure on the X5 (F15) and no go. This would be great to know for forum members in case the engine won't start and you need roll the vehicle or need a tow, flatbed, etc. Many Thanks |
08-20-2017, 08:58 PM | #2 |
Rep 18,628
You have to crank it and move the shifter to neutral at the same time.
That's how I did it when my brand new, one week old, 2014 F15 X5 was stuck in the underground parking of a hotel in 2013 November. But that time, the car wasn't firing up. In the case of the car firing up, I am not so sure how.
08-21-2017, 11:32 AM | #3 | |
Rep 113
http://www.bimmerfest.com/forums/sho...d.php?t=836438 |
08-21-2017, 05:28 PM | #4 |
Rep 9
Thanks
I'll try and located the bolt and will report back regarding bolt size, location, and if tightening the bolt actually puts the vehicle into neutral? |
08-22-2017, 03:53 AM | #5 | |
<3 Flat Four
215
Rep 754
2011 335is Le Mans Blue
08-22-2017, 11:48 AM | #6 |
Rep 980
Chock the wheels first, or win Darwin Award.
08-24-2017, 01:11 PM | #7 |
Rep 1,887
Simply do what you should do anytime you crawl under a car... apply the parking brake, and block a wheel with rock or a brick or piece of wood. C'mon, common sense.
08-27-2017, 09:12 AM | #8 |
1148
Rep 2,426
Also if your on an obvious incline turn the wheels toward the curb.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
08-27-2017, 01:15 PM | #9 |
<3 Flat Four
215
Rep 754
common sense is not so common to a lot of people, car enthusiasts will see the obvious of chocking up a wheel or 2 to prevent it from rolling, but the other regular joe blows, this would prob not even cross their minds before doing it. just look at the whole jeep shifter fiasco, no one seems to know how to operate a shifter properly to put the car in park... then again the regular joe blows will prob call a tow truck in the first place instead of crawling underneath their car.
04-25-2023, 06:49 PM | #10 |
Rep 1,497
Tried to fire up the X5 this morning, only to find the battery was dead. Needed to push it out of the garage so I can jump start it off the wife's car. Just one problem, I couldn't get the car into neutral since the ignition wouldn't fire. Tried for awhile. So, surely BMW didn't design a car that won't go into neutral when battery is dead!?!? I've read you can crawl under the car and loosen a bolt to get it into neutral. If this is truly the only way then BMW lost some points in my book. Anyone know of a hack to get it neutral without crawling under the car?
04-26-2023, 09:37 AM | #11 |
Rep 162
My recommendation would be either to buy a portable battery jump box to use the terminals in the engine compartment to jump start it or just jump start it from the back (since that is where the battery is). I know people say it's not optimum to do it from the back (since it bypasses the electronics). If you can buy a jump box locally I'd go with that.
Yes, agreed it's a poor design but many cars have the same transmission design. It's not just BMW. The similar transmission (ZF) is used in many cars (with the same challenge) |
M302_imola842.50 |
04-26-2023, 09:45 AM | #12 |
Rep 7,361
The answer is in your owners manual. There is a looped wire in the rear left cargo compartment that you pull up.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-26-2023 at 09:56 AM.. |
M302_imola842.50 |
04-26-2023, 10:06 AM | #13 |
Rep 7,361
If you need to use the procedure where you go underneath the vehicle...see the instructions below:
M302_imola842.50 |
04-26-2023, 01:19 PM | #14 | |
Rep 1,532
M302_imola842.50 |
04-26-2023, 03:01 PM | #15 |
Rep 1,497
Luckily, the X5 fired up no problem this morning. Further confusing if the issue is really battery related. The battery is only 1 year old. I however, did not register or code the new battery. I used the method of leaving the trunk hatch open for 15 minutes, allowing the car to go into sleep mode (or whatever the proper term is). Then I simply disconnected old battery then installed the new battery. It's like my car never knew I replaced the battery. All seat memory and presets were retained. Could this possibly be decreasing the life of the new battery?
04-26-2023, 03:28 PM | #16 | |
Rep 1,532
Are you getting any warnings along the lines of "Increased Battery Drainage" or "Replace battery"?
04-26-2023, 05:58 PM | #17 | |
Rep 7,361
04-27-2023, 10:33 AM | #18 | |
Rep 1,497
04-27-2023, 10:36 AM | #19 |
Rep 1,497
I prob need to register it or if O'reilly's does find the battery faulty get the new one registered. I have bimmercode but I believe I've read I will need bimmerlink to register it.
04-28-2023, 10:11 AM | #20 | |
Rep 7,361
Bimmercode only allows you to "code" the battery...which is only required if you change the type of battery (ie from AGM to wet/cell) or if you change the AH capacity of the battery from 90 AH to 105 AH or vice versa. Either procedure is really easy to do if you have the apps.
M302_imola842.50 |
04-28-2023, 12:37 PM | #21 |
Rep 1,497
I will buy the bimmerlink app then. I'm also going to invest in a portable battery jump box just to have in case I run into this issue again. Will be a good thing to take on road trips with the fam as well. Prob just go with a fairly cheap brand that has good reviews on Amazon.
