03-18-2018, 09:44 AM | #4050 |
Rep 40,765
03-18-2018, 10:02 AM | #4052 |
Rep 10
From Argentina
Hi, I m Juan from Argentina. I buyed a 2018 X5 40d.
I would like to change any codes (bimmercode app) and my first doubt is: My x5 has iDrive 5 with touchscreen without Apple Car so I would like to change Idrive 5 to 6. What do you recommended? First change iDrive 5 to 6 and then download apple car? or do on the contrary? Apple Car is not available in Arg, so i trying to do with a UK address. Sorry for my English! Thanks! Juan. |
03-18-2018, 10:09 AM | #4053 | |
Rep 40,765
03-20-2018, 08:07 AM | #4054 |
Rep 1
hi. i have X5 F15 2014 year,America.I want to change xenon (S522)+AHL(S524) on LED Adaptiv Europa,
bought and set the lights, extended the wires according to the scheme "newtis",has changed SZL with function 5AC. Of FA removed S522,S524,S8S4 added S552,S5AC i have :ENET+ E-SYS+ISTA-D please tell me which blocks and how to encode if possible in detail Last edited by btm76; 03-20-2018 at 08:22 AM.. |
03-20-2018, 10:45 AM | #4055 |
Rep 14
Dealer Problem
Hi guys,
Just got from the dealer today with a problem, I purchased the M performance brake kit part #34112348054, after installation they said they couldn't code the kit to the car, i had previously added TPMS, do I just remove the VO coding and that should fix the problem ? They said I need to return the car to it's original setting, or I have to VO code all modules !!! This was done on 2018 X5 50i Just found the coding steps, apparently they found a conflict between factory FO and current FO so they just panicked and refused to code it ! They actually refitted the original brakes back on and said they won't release the car with the M brake kit !! I have to reset the FO, take the car back to them, remove the original brakes again and refit the M brakes again ! One more thing, hoe come E-sys I'm using only shows numbers under the vehicle profile folder list, I'm using launcher premium v2.8 ?? Last edited by kariem; 03-20-2018 at 03:44 PM.. |
03-20-2018, 08:48 PM | #4056 |
Rep 591
Any idea how to code the rear turn signal behave like the Audi. Instead of the entire lamp blinking it would start with the LED closest to the license plate then move towards the outside then starts again, you know what I mean right.
03-21-2018, 12:20 AM | #4057 | |
Rep 8,364
VO code BDC Body, FLA or KAFAS, and Both LHM/TMS or FLE. Then, use ISTA+ to initialize. |
03-21-2018, 08:20 AM | #4058 | |
Rep 3
My actions: 1. Stretched to every 1 power wire to the headlamp from the front (to the left of Faro) and back (right headlamp) Toko-distributor 2. Changed under the Steering switch to European auto-far 3. Changed configuration: via VO Coding removed from FA 522, 524, 5a1, 8s4 Added 552, 5ac lamp not earned Сoding: 4. TMS units appeared and LHM, for which use the ' Detect CAF for SWE ' added for: (41) TMS_L cafd_00001082_032_001_000 (f025-15-11-505) (42) TMS_R cafd_00001083_032_001_000 (f025-15-11-505) (43) LHM_L cafd_000010ba_001_008_051 (f025-17-11-520) (44) LHM_R cafd_000016bf_001_008_051 (f025-17-11-520) VO code: BDC_Body, KAFAS2, (41) TMS, (42) TMS, (43) LHM, (44) LHM Earned middle, ring and turn signals do not work- - LHM_L and LHM_R blocks the error disappeared, but the STML and STMR stayed - Initialization using Ista+ does not pass, writes-coding error Not initialize when performing service function error-programming interrupted with error. When bought headlights, new seller said. ??? I can break both modules if I connected LAE headlights instead of xenon without changing the wiring and changing the FA ??? I came across such a description on one of the forums: When you completed the manual work remember to NOT INSTALL THE LED HEADLIGHT BEFORE HAVE CODED FA (Veichle Order) AND FRM ECU. This step is FUNDAMENTAL, because FRM send different signals to headlights depending of the configuration, if you install LED but the car and FRM is coded for xenon simply you risk to burn your thousand € or $ headlight!!!!) http://f10.5post.com/forums/showthread.php?t=1355907 please somebody, if possible for more details where and what to fix? Last edited by yura79; 03-21-2018 at 10:20 AM.. |
03-21-2018, 09:28 PM | #4059 | |
Rep 8,364
Hopefully someone else can chime in. |
03-22-2018, 07:04 AM | #4061 |
Rep 40,765
No. v.4.10.21 is.
03-22-2018, 08:27 AM | #4062 | |
Rep 3
(tms_type, tms_variant, tms_id.....)??? |
03-22-2018, 03:00 PM | #4064 |
Rep 40,765
PM sent.
03-24-2018, 06:04 AM | #4067 | ||
Rep 8,364
Audiocracy2.00 |
03-24-2018, 09:48 AM | #4068 | |
Rep 40,765
Audiocracy2.00 |
03-24-2018, 03:47 PM | #4069 |
Rep 3
Hello. Can you please tell me if it's possible to coding a digital instrument cluster (6WB) , so that at night it is in day mode? That is, to keep it white, not red. The red is just awful, like a 2000 car and I work as a taxi driver.
Screen white: Screen red: I'm sure this can be done by coding, as it changes depending on the lighting on the street. That is, the light sensor somewhere makes 6WB change color. Last edited by MachineYOO; 03-24-2018 at 03:53 PM.. |
03-24-2018, 07:52 PM | #4070 |
Rep 428
Drives: 2015 X5 35d
Possible to get the latest coding software?
Thanks in advance! |
