01-22-2015, 10:31 AM | #23 |
Rep 198
Update: Just bought a 240GB Kingston HYPER SSD , formatted to exFAT works without a problem so far. Haven't tried the NTFS mode just yet.
01-22-2015, 10:41 AM | #24 |
Rep 258
Been using this and it's working perfectly fine. 128gb SSD bought it for $29.81
http://www.samsclub.com/sams/128gb-o...ab=allProducts |
01-22-2015, 05:48 PM | #26 |
Rep 1,886
I used this: http://www.amazon.com/Silicon-Power-...lash+drive+3.0 comes in 64 and 128 GB. Small, easily removable.
01-22-2015, 11:09 PM | #27 |
Rep 1,744
You guys know that USB cannot utilize the SSD speed and it's not much faster than other drives, right? Just get a USB stick and save your space. I went with Sandisk Cruze Fit http://www.amazon.com/dp/B00FJRS6QY/...ing=UTF8&psc=1
However, that SSD for $22 is amazing, can that SSD be removed and used as internal drive?
09-26-2015, 12:52 PM | #28 |
Rep 238
Just picked up wife's 2016 x5 with the rear entertainment. Is there a guide as to which formats it will play and how to convert media to playable scale?
03-14-2018, 01:37 PM | #29 |
Rep 2
128GB USB
I had a 16GB USB which read perfectly in my car. After upgrading to a 128GB, I now have to unplug and plug the new thumb drive. Both are formatted to FAT32.
Does anyone out there know how to remedy this or is my thumb drive bad/too large? |
03-14-2018, 01:41 PM | #30 |
Rep 1,260
Format it to NTFS.
03-17-2018, 09:00 PM | #31 |
Retired Curmudgeon
2985
Rep 4,047
Sorry to thread jack a bit, but what resolution files can the system decode. 44/16 is standard CD resolution. I have 2+ TB of hi-resolution files for the audio system. I'd like to play better resolution than the low resolution stuff on my phone. Thanks!
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
Kokiiiz8.00 |
03-18-2018, 10:09 AM | #33 |
Rep 493
Here my experience, on an 2015 X5 with professional NAV system and B&O audio:
1. Both .mp3 and .flac audio files work perfectly. Flac files sound clearly better, if the original music quality is good enough. 2. a 128 GB Samsung USB "thumb drive", formatted either NTFS or FAT32, works perfectly - Sandisk brand ones seem more laggy, can't tell why. 3.. a Samsung T1 1 GB flash SSD drive works perfectly - my one stores some 3000 flac audio files and 150 movies. X5 coding allowed different (already present but not enabled) video file types to play perfectly. mp4 videos based on the H264 codec (the usual Blu Ray one) work fine, but H265 (the latest high compression 4K codec) does not seem to work. The SSD drive uses some .1 to .3 A, easily supplied by the USB plug. NOTE 1: allow 5 - 10 minutes for a one-time file system reading the first time you plug in a large SSD drive. You cannot access your files before that, be patient. NOTE 2: to access your videos in the car you can use a nested (multi-level) folder system to organize the video files - but not so for the audio files and their artwork: these need careful "tagging" - you may use "Tag&Rename" or similar software to organize them. Caution: do not ever allow Tag&Rename to "organize" your video folder, it will mess it. |
03-19-2018, 02:40 AM | #34 | |
Rep 26
03-19-2018, 10:12 AM | #35 |
Rep 493
"I have H/K system not B&O....so do you think it is the reason that I can't play FLaC and only MP3?"
--- A good question but I don't know the answer, sorry. Anybody else? |
06-03-2018, 05:33 PM | #36 |
Rep 3
