03-20-2017, 08:37 AM | #1 |
Rep 13
2017 X6 Tailgate Opening On Its Own
So, the other day the tailgate decides to open up two times on its own while I was idling along... Has this happened to anyone else? The second time it happened, I was backing up and hung the rear end over a sidewalk... The tailgate immediately opened up.
2017 BMW X6 35i M-Sport
03-20-2017, 08:50 AM | #2 |
Rep 11,843
Drives: MY24 G01 AW Msport
where do u keep key?
03-20-2017, 09:14 AM | #3 |
1150
Rep 2,426
It's easy for the key buttons to be depressed in your pocket. Mine happens on occasion too.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
03-20-2017, 09:34 AM | #4 |
67
Rep 308
That a pretty f'd up situation to say the least - I can't believe this isn't suppressed at a certaint speed - the damn cameras are non functional over 10 MPH. What speed were you driving?
03-20-2017, 01:48 PM | #5 |
Rep 13
In my jacket pocket. First time this has ever happened.
03-20-2017, 01:50 PM | #6 |
Rep 13
Both times the vehicle was in gear. Probably 1-2MPH... basically idling. I couldn't believe it. Happened twice within minutes of each other. Just made no sense when the car was in gear for it to just pop like that. I was afraid it was gonna hit the top of my garage door and cause damage. I was able to stop it both times.
03-20-2017, 03:08 PM | #7 |
Rep 204
I have my Keys inside an MPerfromance Key case for this very reason (and scratching the keys)
Ordered: 2024 BMW M240i XDrive Current: 2020 BMW X6 Xdrive40i M Sport Previous: 2020 Porsche Cayman S Previous: 2017 BMW X6 Xdrive40d M Sport |
nyalpine907431.00 deutsch1003936.00 |
03-20-2017, 03:44 PM | #8 |
Rep 16
Drives: 2024 X5 M60I Carbon Black
Here is the answer to your question.
I had the same thing happened to me number of times. I had to go to BMW dealer to fix it. They will reprogram your remote, so you would need to push the open trunk twice. Please see the attachment TBS for fixing. Print it out and show it to your SA.Tb BMW (1).pdf
MN2///M521.00 deutsch1003936.00 |
03-20-2017, 08:01 PM | #9 | |
Rep 748
03-21-2017, 06:49 AM | #11 |
Rep 11,843
definitely take a trip to service dept, its probably faulty sensor
03-21-2017, 12:27 PM | #12 | |
Rep 496
03-21-2017, 12:49 PM | #13 |
Rep 748
Guys, it read there in the bulletin:
"CAUSE • Vehicle key trunk/tailgate button may accidentally be pressed, thus opening the tailgate" Solution is to re-program the key to press the "trunk" button TWICE.
03-21-2017, 02:09 PM | #14 | |
Rep 222
03-21-2017, 02:27 PM | #15 | |
Rep 496
03-21-2017, 03:10 PM | #16 |
Rep 204
On my 2017 F16 you have to hold the trunk button on the key down for a few seconds to open it, don't know if that's an improvement on before or not but it certainly isn't a "press" and open.
Like I said earlier though, I have a case for it so likelihood of accidently pressing in any situation is nil.
03-27-2017, 10:50 PM | #17 |
Rep 60
In addition to reprogramming the key fob ( pressing twice to open ), you could also set the opening height of the trunk lid so as not to hit the garage door when fully opened. Just in case
03-29-2017, 07:37 AM | #18 |
Rep 108
What is the coding to enable double press of the remote key button to open the tailgate? I know the ECU, but I don't know the exact changes for double press.
HKFM2 300A REMOTECONTROLLIFTGATEBUTTON
2017 X5 xDrive40e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD + Glare Free High Beam), ACC Stop & Go, Night Vision, 275/40R20 315/35R20 Pirelli PZero + Pirelli Scorpion Ice & Snow
2018 330e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD), Active Blind Spot Detection, ACC Stop & Go, Parking Assistant, Side/Top Cameras, HUD, Comfort Access, 225/45R18 255/40R18 Pirelli Cinturato P7 + Winter Sotozero Serie II |
04-17-2017, 04:09 PM | #19 |
Rep 3,074
Drives: G06/G20/F30/F15/F10/E90
This same thing happened to me as well, parked the car in the garage, locked it, went inside, then two hours later came back and the tailgate was open my car is 4 days old
04-18-2017, 08:58 PM | #20 |
1636
Rep 2,995
04-18-2017, 09:40 PM | #21 |
Rep 11,135
Happened to me on three occasions. Once when I was driving in traffic, twice when the vehicle was parked inside. Took it in, no faults found. Unable to prevent the key from opening the rear hatch.
04-19-2017, 11:29 AM | #22 | |
Rep 3,074
The problem is I park my car in downtown Baltimore and do not to come back after 8 hours to find the tailgate open, that would be bad |
