      03-07-2018, 01:42 AM   #23
mkdan2004
Drives: BMW X5 F15
Same here. Ironically it is much easier to take it out than to put it back on. I had mine painted and installed in a shop and the guy had to literally remove the protective shield at the bottom of the car in order to put his hand from the inside to clip it back.
      11-03-2018, 01:55 PM   #24
flagman5
Drives: 2015 x5 xdrive35i
hello all
I am having alot of trouble putting this piece back in. The back is a closed plastic shield so I cannot do anything from the back. I tried pounding it in with a rubber mallet and none of the clips will catch.
is there anything else I can do here? how do I epoxy the piece on? there really isn't a flat surface that I can apply the epoxy to.
Update:
sighs one of the 2 side tabs on the broad end has broken off. there is still one tab left and I am thinking the narrow side clips should hold if caught....
      11-03-2018, 07:11 PM   #25
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
Originally Posted by flagman5 View Post
hello all
Update:
It's a really bad design. If tabs are broken - either ebay a new piece or use a clear waterproof silicon that is sold in small tubes - apply it in small amount on back of your current T-piece and put it back - it will hold. Silicon will set in 30min and will hold the T-Piece. Clear silicon is transparent and is not visible and can be removed if needed. It's not as messy as glue and it's more gel like consistency so you can stick it to the trim panel without much issues and remove later if needed.
      11-04-2018, 10:16 AM   #26
alphaod
alphaod's Avatar
Mine didn't sit flush either after I removed it to plastidip... maybe that's a good thing I can remove it more easily when I need to redo the coating on it...
2015 BMW X5 xDrive50i
BMW CCA 509766
      11-04-2018, 10:47 PM   #27
flagman5
Thanks, I have a caulking gun with a silicon tube and just used it to seal up the piece all around.
DuSh2113.50
      11-05-2018, 12:38 AM   #28
sj22
Drives: 14 F15 50I
Be careful, it may fall off if the bumper hits the curb while parking. I learnt it the hard way.
OP bought mine $40 shipped on ebay 6 months ago.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors
Past: 2013 750i xdrive, 2008 535xi
      09-26-2019, 02:02 PM   #29
Atomicteal_M3
Atomicteal_M3's Avatar
Drives: E90 M3 AW
2007 335i  [9.00]
Great info here. Will try this on my X5
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
      10-14-2019, 04:09 PM   #30
spinedoctor
Drives: 2015 BMW X5 50i
Genius
My man did it with ONE hand holding the camera
Half the battle was finding out what these things are officially called.
      10-17-2019, 09:59 AM   #31
eldogo
eldogo's Avatar
Tanzania
274
Drives: BMW 328xi BMW X5 F15 BMW M2
2017 BMW M2  [0.00]
I did this a while ago. I decided to spray paint them after failing to get a clean wrap.
      09-20-2023, 08:17 AM   #32
lo7100
Drives: X5
Hi Eldogo,
Can I ask where you get the front bumper lip?
Thanks
