03-04-2018, 08:24 AM | #1 |
Rep 1,434
A few dyno questions
Hi guys been around these forums for awhile with owning prior BMW’s, I have searched but haven’t found much so thought I would ask . I just picked up a 2014 x5 50i cpo with 40,000 miles (wife’s car lol) , I want to dyno it and get a baseline. I have had a lot of my prior cars on the dyno which where manual cars , so what is the correct way to dyno the 50i ? I know for sure turn of dsc/ put in sport+ , but what gear ? 4th? I’m sure the guy who will dyno the car should probably know but just in case he is not familiar with dynoing BMW, he tunes my fbo evo 8 . Once I have a baseline , I would like to do light mods, will start with fresh plugs , add piggyback, and do the M air filters.
Thanks John
2022 x5 m50i - Dravit grey
03-04-2018, 08:32 AM | #2 |
Rep 18,713
John,
I believe it is between 3rd and 4th gear. So, either one is good. The delta is the important number. If you are trying to get base number to compare it to the BMW claimed power, good luck.
CT335xi684.00 |
03-04-2018, 08:35 AM | #3 |
Rep 1,434
Thanks Ben! Your quick to reply. I will definitely post results when I get them.
r33_RGSport12967.50 |
03-04-2018, 11:48 AM | #4 |
Rep 1,180
You might want to consider reaching out to Dinan or checking their site for base dyno numbers. They usually post the base numbers as well as the post-tune numbers.
They can prob also give you an idea of their process to dyno.
2018 X5 35i M-Sport
CT335xi684.00 |
03-04-2018, 11:53 AM | #5 |
Rep 231
Just be sure to let the dyno tech know about the step down in the throttle. I'm not sure if manual mode overrides that or not. Ive seen a few mash it and cause for a start over.
Also, it might be 6th gear for 1:1 in the 8 spd trans, but might want to do 5th for quicker pulls. |
03-04-2018, 11:57 AM | #6 | |
Rep 1,434
03-04-2018, 12:38 PM | #7 |
Rep 2,388
When I did it - we did it in 5th gear and then 4th. It doesn't matter eventually - it will give same power values, but with 6th gear you may hit speed limiter, if you are stock, so probably staying with 4th and 5th is better.
Please post stock dyno numbers, I'm very interested. What kind of dyno? |
03-04-2018, 01:09 PM | #8 | |
Rep 1,434
03-04-2018, 04:52 PM | #9 |
Rep 648
Drives: 2016 F15, 2015 F83
I've dynoed my 50i M sport on a mustang dyno a couple of times. Here's what you need to know:
6th gear is the 1:1 gear, but you will hit the speed limiter before redline, so 5th gear is the one to use. On my vehicle, pulls in 5th and 4th produced the same numbers. Use the following modes/settings: -Make sure all doors and hood are closed -Sport+ -Sport shift (transmission lever to the left) so that it doesn't downshift when you floor it. Sport+, Sport Shift and manual gear selection are all required to prevent downshifting. -DSC & DTC completely off (hold the traction button for a few seconds) -PDC off -Accelerate and manually shift into 5th -Introduce the back of the pedal to the carpet
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 03-04-2018 at 04:59 PM.. |
CT335xi684.00 |
03-04-2018, 04:55 PM | #10 | |
Rep 648
2015 F83 M4 |
03-04-2018, 05:12 PM | #11 |
Rep 231
Those numbers are pretty good, I know mustang dynos are different, I actually prefer those numbers, my buddies averages out ~18% lower then dynojets. The most important thing is the delta anyways.
03-04-2018, 05:13 PM | #12 | |
Rep 1,434
03-04-2018, 05:15 PM | #13 |
Rep 1,434
Joyride you are absolutely right as all that really matters is the delta to see if your mods actually made any power improvements.
03-04-2018, 05:54 PM | #14 |
Rep 648
Exactly.
2015 F83 M4 Last edited by Rotzy; 03-04-2018 at 06:05 PM.. |
04-11-2021, 11:02 AM | #15 | |
Rep 1,859
Drives: 23' X7 40i M Sport
Too bad we don't have a Dyno mode setting! |
04-11-2021, 11:26 AM | #16 |
Rep 648
Some vehicles will not go into gear with the hood open. You either need to close the hood or trick the sensors.
2015 F83 M4 |
classic_erik2808.50 |
04-11-2021, 11:29 AM | #17 | |
Rep 1,859
Have my first dyno scheduled for the end of the month and will make sure I have your checklist in hand. Thanks!
M302_imola842.50 |
04-11-2021, 09:12 PM | #18 |
Rep 1,497
