03-07-2018, 02:04 AM | #1 |
Rep 20
X6 F16 Headlight Bulb Change?
Hi guys,
I noticed that my headlights are not LED They are also not particularly bright as I'd like. I understand that they are a D1S HID bulb. So I was thinking of upgrading them to a 6000k or 8000k HID bulb. Has anyone changed one before? Was is easy? How is the D1S held in place? Many thanks in advance |
03-07-2018, 03:41 AM | #5 |
Rep 20
03-07-2018, 10:43 AM | #6 |
Rep 842
Most OEM bulbs are 4300k which I believe is the whitest light. 6000k will be bluer and also look less bright.
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
03-07-2018, 10:53 AM | #7 |
Rep 1,180
Get Osram CBI. Have them in my F15 and ran them in my JGC. Light output is same as oem but much whiter. Lots of reviews and tests out there on this bulb.
Installation is also super easy. Far easier than I was expecting based on experience on E36, E46 and JGC. Some good info and testing against other bulbs here: https://www.hidplanet.com/forums/for...-d2s-bulb-test Edit: Looks like Osram has come out with two newer models, the CBH and CBB. They are incrementally more expensive. both have a higher K rating. Not sure what the sacrifice in visibility is. Also be wary of fakes and be sure you purchase from a reputable retailer.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner M-Perf Exhaust and lip Wheels: Winter - 469m; Summer - Vossen CV7 22s 2018 X1 28i M-Sport Last edited by CeeTeeX5; 03-07-2018 at 11:25 AM.. |
Doanster626.50 |
03-07-2018, 11:14 AM | #8 |
Rep 1,181
OP, as CeeTeeX5 pointed out above, read up at HIDPlanet. Lots of good info. Sounds like you want a better "look" vs actual improvement in light output. 8000K is horribly fake purple. The reason i3 headlights appear purple is because of the optics, not because of the bulb temp.
5000K is the most I'd personally go up.
10-27-2018, 12:17 AM | #10 |
Rep 442
Went with the osaram CBB so much brighter than stocks in the f15. Installation was super easy just pull down the connector and twist the bulb a little and it pulls right out. No clips or tabs that has to be removed or pulled apart. Wayyyyy easier than a e70 and you have a lot of room. Super happy with the light output with the cbb and you get a nice white light with a slight bulb tint depending on the angle you look at it but big difference from stock.
10-27-2018, 11:30 AM | #11 |
1148
Rep 2,426
If anyone wants a pair of Sylvania SilverStar (aka Osram CBI) bulbs let me know. I got them like 8 years ago when I had my E70, but all my cars have LEDs now.
10-27-2018, 12:17 PM | #12 | |
Rep 1,092
05-27-2020, 03:22 PM | #13 | |
Rep 1
D1S bulb removal
Is it right to install and Left to remove? I tried both ways, it seemed like I was exerting too much force, so I stopped. Thanks in advance. Robert |
05-27-2020, 03:34 PM | #14 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
I have HIDs - and bought the bulbs - Ben tried to swap them but could not.
Are they plug and play with the Xenon and adaptive lights?
2020 BMW X5 M-Sport
2021 Audi Q7 Prestige 2016 Aston Martin Vantage V8 |
05-27-2020, 04:49 PM | #15 |
Rep 1,066
Drives: 2015 X5 50i M Sport
They are plug and play. Extremely simple.
2019 Cayenne Turbo
05-28-2020, 02:10 PM | #16 |
Rep 166
Same as a screw: anti-clockwise to remove, clockwise to install (as you view it from the engine bay). You do need to use more force than I initially felt comfortable with.
05-28-2020, 05:11 PM | #17 |
Rep 471
The higher you go in Kelvin the actual less lumens you have so while you think a 6000K bulb is brighter than a 4500K bulb its an optical illusion because it's whiter (given everything else is equal in the bulbs). I agree with prior posts that close to 5000k is the way to go, I'm not a fan of the hint of blue in 6000k bulbs.
Official Osram CBI or CBB are the way to go. Last edited by Florida-X3; 05-28-2020 at 05:19 PM.. |
