03-14-2018, 07:54 PM | #1 |
Rep 788
Adding Subwoofer To F15 HK?
Curious if the hardware/process is the same as the F30/80 Harman Kardon?
Basically, tap into speaker line for signal, aux line to trigger remote wire, and utilize the LC2i to control the bass levels? There is a lot of space in the storage area under the rear cargo floor to put a small subwoofer/amp to fill in some of the low end, and I believe the battery is also back there allowing for easy wiring. |
03-14-2018, 08:37 PM | #2 |
Rep 211
I believe you'll find cleaner signal via input leading to the factory amp, rather than tapping the amplifier speaker signal leading out to the speakers.
I put a small sub & amp in our MB W212 this way (tapped inbound signal going into factory amp in the trunk). Had a remote sub dial in the center console for bass control. This was also an HK setup, and also had a battery in the boot for the start/stop. Very easy. Did it for some bass in some cases, but we're not "bumping" by any means...just lacked factory bass in the W212 HK setup.
2014 X5 x35 F15
