05-08-2014, 08:55 AM | #1 |
Rep 55
Drives: '14 X5M Sp/'06 M3/DD:Inf QX4
Running Board For M Sport
Has anyone found a decent after market running board that will compliment the look of the M sport? Since BMW decided to delete the option. Thanks.
05-08-2014, 11:15 PM | #3 |
Rep 18,685
I would convert to the OEM side step. Should look ok with the M Sport front and rear.
05-08-2014, 11:33 PM | #4 |
Rep 428
05-09-2014, 12:06 AM | #5 | |
Rep 3,307
I do like the boards on an x-line and maybe luxury (not sure about that one either), but definitely not on an m sport. |
05-09-2014, 12:15 AM | #6 |
Rep 561
I have to agree with Chris on this one. The flared sills works perfectly with the M-Sport but if you were to mix and match then it'd really look "off." The X5 is pretty low, I can't imagine why a running board would be needed unless you plan to install a rack system above and need a way to reach above.
05-09-2014, 12:22 AM | #7 |
Rep 18,685
I do agree as far as the looks. But I would stick with the OEM instead of some aftermarket. At least it would still be designed for the car.
05-09-2014, 07:56 AM | #8 |
Rep 55
Pretty sure eventually someone with the right vision will design one that will look great on it. It's a supply and demand. Thanks.
