08-26-2019, 02:33 AM | #4974 | |
Rep 2
F15 2017 problem coding with Esys
Hi
About an F15 2017, wanted to do some codings. Have installed Esys 3.27.1 and PSdZ 5.01.02-2015-08-12. I have to try 2-3 times to connect successfully because I get an " Incompatible ECU" something like this. After 2-3 tries I get "Connection Established". Then I Click Read FA . Save FA . When i Click READ SVT . It shows this: Quote:
Is it about the old Esys or PSdZ because when I click about I see 2015-08-13 , maybe it doesn't work for cars manufactured after this date? |
08-26-2019, 08:49 PM | #4976 |
Rep 15
After deciding to attempt a self-install of the trailer harness on my 2015 F15, I am now drinking from the firehose and learning more than I ever wanted to know about coding.
May I too please get the infamous PM? I promise to take good care of her! Thanks!
2009 E90
2015 F15 2024 G05 |
08-26-2019, 10:06 PM | #4977 |
Rep 40,919
PM sent.
09-01-2019, 03:26 PM | #4978 |
231
Rep 369
Hey guys, I'm trying to connect e-sys 3.30.1 to my car and I can't choose connection via VIN.
Any ideas? Thanks
Current
09-01-2019, 09:25 PM | #4979 |
Rep 8,364
09-02-2019, 12:40 AM | #4980 | |
231
Rep 369
After bit of the research I found it I had my firewall enabled, now it all good Thanks Almaretto for tips
Current
09-02-2019, 06:59 PM | #4981 |
Rep 8,364
09-02-2019, 09:41 PM | #4982 |
231
Rep 369
What else can be done with esys other then coding?
Current
09-03-2019, 10:23 AM | #4984 |
Rep 2,514
Yes its in the BDC_BODY check the cheat sheet here
https://docs.google.com/spreadsheets...9s4/edit#gid=0 Lines 74-76. |
Servord30.00 |
09-13-2019, 12:19 PM | #4985 |
Rep 3
Activating Trailer module AHM
I recently installed a DrawTite trailer hitch (does not have retractable hitch) and oem wiring harness. I thought activating it would be simple, but I have spent a week looking at various sites, forums, threads, etc... I thought ISTA+ would be the way to go because I saw something under Software Updates that showed Trailer control unit activation. How hard can that be. After installing a couple different versions of ISTA+ including this latest one (Standalone 4.15) complete with sql databases and PSdZ data I thought I finally had it. When I run a test it identifies the fault and shows that it needs to be encoded. When I continue a measure plan is created. This measure plan wants to program or encode many modules and I am unable to un-select them. It also wants to remove my trailer control module. If I execute the plan it does all kinds of stuff with windows, seats, sunroof, etc... Kinda scary what else it might change on me. Is there a simple way to just activate / encode the trailer control unit (which includes the pdc, camera and stabilization steps)???
Please point me in the right direction. |
09-15-2019, 08:23 AM | #4988 |
Rep 40,919
09-15-2019, 11:41 AM | #4989 | |
Rep 3
1. Enable Fog Lights with High Beams / Flashers. 2. Enable Fog Lights with parking lights. These are also shown in the F15 coding cheat sheet as follows. Coding Description, Module, Section, Function Value, Default Value Enbales Fog Lights with High Beams / Flashers BDC_BODY 3068 NSW_AUS_BEI_FL aktiv Enables fog lights to be on with parking lights BDC_BODY 3068 NSW_EIN_AUF_LDS_STL nicht_aktiv Both of these can be found in the Body Domain Control (BDC_Body) unit. The first can be found under Lighting as "Fog lights off with high beam" where you can set it as Not Active. The second is available under Expert mode as follows. Turn on Expert Mode, scroll to and select section 3068 LceMaster, then scroll and select "NSW_EIN_AUF_LDS_STL", select aktiv. Both of these features will ensure that once you turn on the fog lights they will stay on until you turn off the ignition or turn off the lights. I have not tested it in auto mode when lights turn on and off due to outdoor lighting, A also did not find anything that would automatically turn them on. There are many ISTA and eSys coders here who might have some input on that part. Hope this helps. Good luck! Last edited by davidabaker; 09-15-2019 at 11:48 AM.. |
09-15-2019, 11:44 AM | #4990 | ||
Rep 1,664
09-15-2019, 04:27 PM | #4991 |
231
Rep 369
How to open exhaust flap with Ista+?
Thanks
Current
09-15-2019, 10:19 PM | #4993 |
231
Rep 369
I was hoping I can open it and then unplug the cable
Current
09-16-2019, 10:44 PM | #4994 |
Rep 8,364
