03-28-2017, 09:22 PM | #3257 |
Rep 176
Hi All,
I have a 2016 F16 and I don't have AUTO HIGH BEAM ASSISTANT (5AC). Can I still code it to be on Auto On with the knob on Auto? Thank you. |
03-28-2017, 11:45 PM | #3258 |
Rep 8,364
Only vehicles that have FRM (eg, F010 & F026) can have automatic HBA. Other vehicles, like F016 and F082 must toggle with turn signal stalk button.
03-29-2017, 02:41 PM | #3259 |
Rep 120
Hey guys,
I just coded my 2017 40e and was generally successful, but had a few questions that hopefully someone can answer. 1. ConnectedDrive now doesn't connect or work. I didn't mess with anything in this regard so I'm not sure why it suddenly stopped working. Has this happened to anyone else? 2. Opening the tailgate via remote - I can't find the function values in the HKFM module that are referred to on the cheat sheet. Have these been changed in later models? 3. Has anyone figured out how to decrease the loudness of the lock/unlock chirp? I found an old thread that had reference to a module and function code, but I could not find them for myself in those specified locations. Thanks! |
03-29-2017, 10:59 PM | #3260 | |
Rep 176
For some reason today my BMW Assist disappeared, is that something that might have been inactivated by FDL. I coded lots of things yesterday and just realized it's gone? |
03-29-2017, 11:02 PM | #3261 | |
Rep 176
03-29-2017, 11:28 PM | #3262 |
Rep 120
Yeah, i called and they told me the same thing. It started working again this afternoon.
I also found a thread that has the remote tailgate closing code for 2017s. http://www.bimmerfest.com/forums/sho...d.php?t=951857 Someone really has to update the cheat sheet! Now if I can find the chirp volume.... |
03-29-2017, 11:35 PM | #3263 | ||
Rep 8,364
03-30-2017, 12:01 AM | #3265 |
Rep 176
[QUOTE=Almaretto;21492148]Anything is possible. Do you have a record of what you changed?
Thank you Almaretto, I make a back up everytime i code any FDl. I can use the compare tool to see or, i can code back to default and see if that brings it back, then I'll recode it. I will keep you updated, I'll check in the morning. I have one more question for you I have a 2015 and a 2016 F16 both with the digital cluster, the 2016 has the MSport package with the MSteering wheel. The 2016 shows on the cluster once i put the heated steering wheel on that it is on. The 2015 dosen't show it, is that a software version update that does that or a FDL code? |
03-30-2017, 12:08 AM | #3266 | ||
Rep 8,364
It is a software issue, but may also be an FDL. I am not sure if FDL coding alone can enable. But, you may be able to compare ECU's to deduce. |
03-30-2017, 12:11 AM | #3267 | |
Rep 176
03-30-2017, 12:25 AM | #3268 |
Rep 8,364
03-30-2017, 02:04 PM | #3269 |
Rep 120
Ah, I found the FZD module. I changed frequency high to 2 (can't change it to 1) and it seems to be quieter now. Any thoughts on disabling chirp just for unlock? Thanks for your help so far.
03-30-2017, 02:16 PM | #3270 | |
Rep 176
Thank you, I just got my BMW Connecteddrive back on, it looks like the services were down. All good now. Now I'm going to see if i can figure out the steering wheel icon, ill let you all know if i find anything. |
03-30-2017, 07:37 PM | #3271 | |
Rep 176
Heated Steering Wheel activation and deactivation on Cluster
I have been looking for the code to show the Icon for Heated Steering Wheel Activation and Deactivation for a very long time. I finally found it and I tested on an F16 X6 and F15 X5. it is in BDC_BODY -->3140 PfLinSteeringWheel-->LHZ_CCM Set to AKTIV and you are in business. "LHZ_CCM Comment = Should a check control message (CCM) be sent to the Kombi during manual / automatic activation of the LHZ? (Active = yes)" now I wonder if I can control the temperature of heated steering wheel, the MSport wheel is barely hot, where the other type of wheels are nice and warm. i'm sure it is somewhere in there, if anyone knows where please let me know. thank you for your help. |
ferrarif1321.00 |
03-30-2017, 07:53 PM | #3272 | |
Rep 648
Drives: 2016 F15, 2015 F83
Thanks!
2016 F15 X5 50i M-Sport
2015 F83 M4 |
03-30-2017, 10:31 PM | #3273 | |
Rep 176
BDC_BODY -->3140 PfLinSteeringWheel-->LHZ_CCM Set to AKTIV and you are in business. LHZ_CCM Comment = Should a check control message (CCM) be sent to the Kombi during manual / automatic activation of the LHZ? (Active =Yes) The icon or indicator is now on the cluster. |
Almaretto2374.00 |
03-31-2017, 12:52 AM | #3274 | |
Rep 8,364
You can change temperature of seats and wheel. You can also individually set time between shutdown/start to remember heat for wheel as well as heat/cooling/massage settings for front seats & heat for rear seats. |
03-31-2017, 01:21 AM | #3275 | |
Rep 176
BDC_BODY -->3140 PfLinSteeringWheel I really need to change the wheel temperature it's way too low on the msport steering. I found few things but was not sure what to change it to. It would be great if you can find it. Thank you again. |
03-31-2017, 06:34 AM | #3276 |
'06 525xi, '14 435xi, '17 X5 50i, '16 428xi GC
36
Rep 152
Very nice. Screen shot that so that I can add the indicator. I'm also reading every page on this thread to make sure I don't miss anything. On page 33. 😓
03-31-2017, 12:42 PM | #3277 |
Rep 176
Sure here you go
03-31-2017, 03:35 PM | #3278 |
Rep 648
Wait a moment. Are you saying the coding you discovered only gives you that "pop up" message? I thought you were talking about the little yellow steering wheel "icon" that is higher up on the display?
2015 F83 M4 |
