06-04-2019, 10:17 PM | #89 |
Rep 7,165
Mine is starting to sag again. I think I need to remove the air lines and cut them a bit. I think they're deformed now and it's causing them to slowly leak.
But what's weird is my compressor isn't filling them unless I do it manually in ISTA. FML.
06-04-2019, 10:36 PM | #90 |
483
Rep 317
Your compressor might be timing out to prevent it from burning out, is there any errors in ista?
06-04-2019, 10:39 PM | #91 | |
Rep 7,165
And not really found how to detect errors in ISTA yet. I do run a check on the sensors with no issues that I've seen. And the compressor does fill them after I complete the sensor check. As it does find them low.
06-09-2019, 02:44 PM | #92 |
Rep 2
I found info online, that the suspension air compressor times out because it is water logged. Therfor you dont inflate, not because of leaking bags. There is a simple fix, by emptying the old dessicant from the pump, and replace with fresh dessicant beads. Apparently a $12 fix. Anyone in Bimmerland follow this lead?
06-09-2019, 02:50 PM | #93 |
Rep 2
Problem is, I can't locate the air compressor on my 2015 X5 7-seater. It's supposed to be under the spare tire. I don't have a spare tire, I have a third row, no panels to remove...
06-09-2019, 03:02 PM | #94 |
Rep 1,343
Check newTIS
06-21-2019, 04:48 PM | #95 |
Rep 7,165
The air compressor is under the passenger seat. Access from bottom of the car.
Russmov1328.00 |
06-22-2019, 10:20 PM | #96 |
Rep 7,165
Also found in ISTA that I had a voltage issue with my driver side rear level sensor. So I bought a new one and fingers crossed it helps with the compressor not filling automatically
Russmov1328.00 |
08-11-2019, 02:34 PM | #97 |
Rep 1
Can someone point to the correct cable required to bleed air from air spring using ISTA-D? And where do you get ISTA-D from, amazon link would be helpfull, i’m from UK.
08-13-2019, 11:06 PM | #99 |
Rep 25
I have the same problem.
The driver side suspension is deflated if i start the car for a few minutes and shut or start the vehicule just to move to another parking lot for a minute, then the driver side is all deflated. But if i use the vehicule like normal, it wont deflat. What could be the problem? Thanks for any replay and sorry if im not explaining it well |
08-14-2019, 02:40 AM | #100 |
Rep 1,270
You need to replace the air bags, as they are leaking. And yes, replace both, it's just a matter of time before the other one starts leaking as well.
If you continue to drive like this, you'll burn the air compressor. |
08-14-2019, 03:02 AM | #101 |
Rep 25
05-27-2020, 12:12 PM | #102 | |
Rep 10
11-04-2020, 11:54 AM | #103 |
Rep 10
I previously posted here after fixing the air spring issue, however this time the issue is different.
I have an X5 2014 f15 which is showing me an error “chassis function restricted” so I have done the following. 1-Both air bags have been replaced previously 3 months ago when the car dropped down to the ground level. Recently the car has lifted itself from rear quite high so I did a test on ISTA D which showed me “front left vertical acceleration sensor” so I changed that Now the chassis function restricted error is still there I have also used the soapy water to check if the solenoid valve has any leak, however there is no leak. So I removed the fault codes, and went on a ride however the error came back so this time it’s showing me a different code which is 480DB4 “control time rear left” NOTE: The car doesn’t deflate with the ista D I have to deflate it manually by disconnecting the air pipes which goes to the Air spring, and also doesn’t inflate when I switch on the car, so I inflated with the ista D and it works. So my question is do I need to change the air compressor? Or it might be something else? Any suggestions? Thank you in advance. Last edited by Bch06; 11-04-2020 at 11:55 AM.. Reason: Correction |
11-04-2020, 01:06 PM | #104 |
Rep 2,527
Try to replace desiccant beads in the compressor (https://f15.bimmerpost.com/forums/sh....php?t=1733505) ,also check this thread here
https://f15.bimmerpost.com/forums/sh....php?t=1751937 May be you have similar issue with the valve? |
11-04-2020, 03:23 PM | #105 | |
Rep 10
But what I don’t understand is why is the car not inflating itself when I manually deflated? As I had to inflate it with ista D And when I went on the ride I came back and noticed that the rear is extra ordinary high. So it means that the compressor is working fine but the air is not existing the system, does it means that the valve is block closed? |
11-04-2020, 03:59 PM | #106 |
Rep 2,527
Sounds like there is a chance that in your case that valve stuck open. Before you drop a lot of money on new one take yours out, replaced the beads, check the valve and see what happens.
11-05-2020, 08:15 AM | #107 |
Rep 10
Attachment 2453854
So I did the test again yesterday, and ista d showed me some news faults, I have no idea where did these come from. Also, I have also checked the air compressor all seems to look ok no corrosion or moisture, I am attaching some pictures please have a look, the only other thing I can think of is the ICM unit. Last edited by Bch06; 11-06-2020 at 09:36 AM.. |
11-06-2020, 09:38 AM | #108 |
Rep 10
So the car ride is back to normal as I recalibrated the height adjustments, but the chassis warning is still appearing on the dash, and I’m getting some new codes related to ICM
11-06-2020, 10:17 AM | #109 |
Rep 2,527
I am not a pro on repairing these by any means but the desiccant is dirt cheap , I would replace it regardless since you got it open already. Put everything together, delete faults and drive around the block. See what happens and how your suspension works. You need to troubleshoot one problem at the time.
11-07-2020, 10:55 AM | #110 | |
Rep 10
Good news, since the ride height adjustment I have been driving the car, and the dive has gone back to normal, so I connected ISTA to read the codes, all the ICM codes have disappeared, the only code I was getting was the “transport mode active” so I tried to delete, but it wasn’t deleting, ISTA keep showing a message that I need to put the car in ACTIVE PAD. So when I clicked on the delete transport mode I got the same message so I started the car and somehow the transport mode deleted, yayyy I then retested the car and there were no codes. I went on a long drive on the way back to home I got the “Chassis Function restricted” again I tested the car again and I got the error code 480DB4 “ “control time, lowering, rear left” now either it is the level sensor which is faulty or the compressor valve block. Any thoughts?? Thank you again for the help so far. |
