      10-05-2018, 02:30 PM   #639
mmonsi
mmonsi's Avatar
Drives: BMW X5 xdrive 3.5 i year 2015
Lightbulb
I have a BMW X5 drive 3,5 i year 2015, I will come back to Spain next summer and I need to set Europa maps in navigation, someone could you help me?
      10-20-2018, 02:44 AM   #640
ryegateli
Drives: 2015 BMW X5 Xdrive50i
Hi Guys,
I have a 2015 X5 Xdrive50 I M Sport . I wanted to check on my shocks and struts and wanted to find the right parts. How do i know if y car equipped with EDC or if i have just the standard suspension.
      10-21-2018, 11:15 PM   #641
ryegateli
Hi All,
I bought a 2015 BMW X5 Xdrive 50i recently and i observed the vehicle is going low (level from tires) by the morning and compressor is trying to pump the air in to air springs in the morning when even ever i start the car. Is this common to drop air by the morning ( overnight) , should i replace the air springs ?
      10-22-2018, 03:59 AM   #642
chamindab
Drives: X5 XDrive 40E IPerformance
iPhone not charging from X5 2016 USB port
Hi can someone please tell why my iPhone 7 Plus switches on after I plug it in the X5 USB and switch off after charging starts. When phone is switched off while plugged in to USB it charges faster, but each time I switch the phone off it switches on again, could this be due to a power fluctuation? Same with my IPad mini, which I never charge using the car. Some times the iPhone want charge at all.
Thanks
Chaminda Bandara
      10-22-2018, 04:08 AM   #643
chamindab
Hi
X5 2016 favourite music list is not available after a software update. This list got automatically added with the frequently played MP3 songs. So automatically I ended up with favourite play list. Now even the menu item is not there.
Has anyone had the same experience? How to get this cool feature enabled again.
Thanks
Chaminda Bandara
      10-22-2018, 04:16 AM   #644
chamindab
X5 console mood light not working
Hi does the X5 2016 have a center console area
light to lit up the cigarette lighter and cup holder area at the front, just below the radio memory buttons?
Is this light red colour.
I remember having this but does not work anymore.
Thanks
Chaminda Bandara
      11-07-2018, 08:02 AM   #645
elevenmonkeys
Drives: 2018 F15
Hey man I live in Toronto and had the same problem. The noise on my car came from the trunk spring. No part was replaced, but the technician did do some adjustment. It's trial and error. Try another dealership if BMW toronto won't acknowledge the problem.
Originally Posted by aymanb View Post
Hey Guys!
I need your help. I faced one problem with the trunk of my BMW X6 2016 and I do not know what to do with it.
Not long ago I heard a horrible rattle sound from the back of my car. I stopped by a dealer in Toronto, Canada.
The first time, he did not hear anything. The second time, he told me that it is a plastic trim and that is fine. The third time, they told me that that is normal for a 2-year-old car and they will not be able to help me.
The video of the sound I recorded today can be found here https://drive.google.com/open?id=1_F..._AluGGjhPgWVj6
Have you faced with the similar issue? If so, how did you fix it?
Thank you so much for your help! Appreciate your advice.
      11-14-2018, 06:14 PM   #646
LEX111
Drives: bmw x5
Bmw Music Collection
Hi to every one
i have bought BMW X5 30D Sport pack 2017 and there are some issues i couldnt figure it out
i will try this forum hopefully ill get a reply
remote and in car button tailgate opening/closing:
its weird sometimes when i press the button it just open the gate but doesnt go up. and in some cases it goes up but when i release the button it stops. and sometimes it goes up or down automatically at the adjusted level
very strange. i have had cheaper SUVs like hyundai and i didnt have to figure out howlong i have to press the button
any ideas?
      11-16-2018, 03:49 PM   #647
mpowered5
mpowered5's Avatar
433
Drives: E34 M5
X5 made its first trip to the dealer for some non scheduled repairs.
I haven't brought up yet until my warranty is closer to being done but my steering column is getting noisy.
I got the "wrong fluid added" error and CEL.
a NOX sensor is to be replaced on Monday.
Lastly the driver side vents are blowing warm air , cold air , warm air. I had the same issue with my GMC pickup. Which turns out to be the same problem here. A Blend door actuator need to be replaced which means the whole dash has to be removed. GREAT.
2015 x5 35d - 45,000km.. not miles.
2015 X5 35d M sport
2017 340i M sport
1991 M5
1988 M5
      11-16-2018, 08:26 PM   #648
AnotherM3
AnotherM3's Avatar
Drives: 2008 AW e92 M3
Just picked up a CPO 2015 X5 50i xDrive the other night.
I had to drive about 2 hours to pick it up and sadly I had the drivetrain malfunction pop up halfway home.
Once the malfunction popped up, the truck went into limp mode and loss power.
Took it to the dealer closer to my house and they replaced the high pressure fuel pump.
All is well now. Hopefully that's the first and last of my troubles of having the car for less than half a day.
IG: It_M3_Tooo
      11-16-2018, 08:31 PM   #649
gpitts
gpitts's Avatar
247
Drives: 2023 G07 X7 40i
I've had a couple of issues recently with my 2015 X5 35d I thought I'd pass along. Just before my factory warranty expired (thankfully!), my fuel pump died and in the process threw small pieces of metal into the fuel system - tank, lines, and injectors. All of the fuel system was replaced under warranty. I was told that BMW was seeing quite a few of these failures, so heads-up out there! Yesterday, my CEL came on and she's back in the dealership today with a faulty EGR cooler. That's being repaired, and my understanding is that this is also a known issue that BMW is repairing under a "campaign".
Are there other frequent issues that I should be aware of? Trying to decide whether to keep her. <edit> She has 45.5K miles on her. </edit>
2019 G05 X5 40i, Phytonic Blue, Black Extended Merino Leather Interior
      11-17-2018, 08:45 PM   #650
vanguard
Drives: X6
Need some help with my X6 that I just got.
It came with the 599 21" wheels with Summer tires.
I really dont want to run a double wheel setup and would like to get an all season set of tires.
What are my options for those 21" wheels? There are no 325/285 staggered all seasons. I dont mind going square, if possible.
      11-18-2018, 06:03 AM   #651
A-4WD
Long Time Bimmer Fan
Drives: 2014 X5 35i
21" is not a common size, your options are limited and the tires aren't cheap. I have 21" too but running a double setup.
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded
1990 325iS - Sold
1985 318i - RIP
      11-18-2018, 06:05 AM   #652
A-4WD
Drives: 2014 X5 35i
Sorry to hear that and good luck...I would be losing it!
1990 325iS - Sold
1985 318i - RIP
AnotherM3224.50
      11-18-2018, 06:08 AM   #653
A-4WD
Drives: 2014 X5 35i
I had the same problem with the noisy steering column...actually it was loud AF. Anyway, there is a "bulletin" out for this with the dealerships so it should be a no-brainer. Mine's been fine since they fixed it last year.
1990 325iS - Sold
1985 318i - RIP
      11-18-2018, 11:59 AM   #654
AnotherM3
AnotherM3's Avatar
I was so pissed, but it happens I guess. I should buy a lottery ticket with my luck
IG: It_M3_Tooo
A-4WD215.00
      11-26-2018, 04:26 PM   #655
imkazaam
Drives: 2015 i3, 2014 x5 3.0i
Rear air springs/suspension air bags failed, and the car was 2 weeks out of warranty when we brought it to the dealership. They won't cover it.
The other detail. We went to dealer #1 in August and they told us the warranty expired in July. In October when we visited dealer #2 and they fixed an oil filter housing leak under warranty. The car had a 'demo extension warranty' they were able to see and we got a repair under warranty at that point. Is it worth complaining to dealer #1 or going to BMW NA about this to get the air bag issue covered? Wife also has pictures and video showing the issue occured while the demo extension warranty was in effect.
      11-27-2018, 02:55 AM   #656
androsk1971
Drives: F15 X5 40d / F10 520d
Had an issue when I first drove my car since I noticed a squeeze coming right from the tailgate but couldn' say for sure where from. Finally I took it to an authorized garage and found out that was coming from the isolation rubbers from tailgate. There is a specific lubricant-like product from BMW that fixes the problem. It costs around €40. Attention; use only the original one since an imitation or Vaseline-like products could damage the rubbers.
Usually squeeze occurred in slight anomalies of the street, sudden braking, road humps.
      11-27-2018, 06:47 AM   #657
A-4WD
Drives: 2014 X5 35i
When you say squeeze, do you mean like a squeaking or creaking sound from the tailgate? Did it happen more when you when over certain bumps, or on incline turns (like turning into the parking lot at a mall and there's a ramp)?
I ask because that's what happens to mine lol.
1990 325iS - Sold
1985 318i - RIP
      11-27-2018, 10:57 AM   #658
Road Carnage
Road Carnage's Avatar
Drives: 96 328is, 15 X5 50i
I picked up my 2015 X5 5.0 in September coming off a lease with 34,000 miles on the clock. When I brought it in to the dealer the first week for inspection I mentioned that the brakes were spongy and that the steering column position controls (up/down, in/out) were intermittent. Dealer replaced the column and installed new brake pads/rotors all around under warranty.
      11-27-2018, 10:28 PM   #659
Stev_chu
Stev_chu's Avatar
108
Drives: 2015 BMW X5
What do you meant by spongy
      11-28-2018, 05:43 AM   #660
Road Carnage
I define Spongy as - soft pedal feel, having to press too hard for the amount of braking you are getting. Not a firm, confident feel while braking. Sort of like stepping on a sponge.
Hope that makes sense.
