08-10-2021, 09:00 PM | #309 |
Rep 30
I've decided that I'm going to do the speaker and sound deadening installs myself. I just need to make sure I get the correct equipment that will work together. Here is the setup/combo I am considering...
Amp: https://www.audiotec-fischer.de/en/m...ifiers/up-7bmw Under seat subs: https://www.audison.eu/products/apbmw-s8-2/ Mid-range//tweeters: Front doors: https://www.focal.com/en/car-audio/c...wr/is-bmw-100l Rear doors: https://www.focal.com/en/car-audio/c...mwr/ic-bmw-100 Can anyone chime in and make sure this setup will work together. Specifically regarding the output of the amp with the subs/mid-range/tweeter. Any help would be appreciated. TIA |
08-17-2021, 03:07 PM | #310 | ||
Rep 23
I wouldn't get that amp. It is essentially the same power output as the factory HK setupp. It is equivalent to the revenant, not the newly released revenant pro. To get the equivalent amp to rev pro, that would be the Arc Audio PS8-50. They retail for about $1100 and you can play with the dsp. |
08-17-2021, 03:08 PM | #311 | ||
Rep 23
I would also get the 2 ohm underseat subs. I purchased the 8 ohm from BAVsound and that was a mistake. |
08-18-2021, 05:30 PM | #312 |
Rep 30
Thanks Shoop. I had already purchased the amp last week, so too late for that. I have the HiFi system, not HK, so this should still be a big upgrade. As for the subs, I did purchase the 2 ohm, arriving tomorrow. I am still undecided about the mids/tweets. I really want the Focal ES100k, but still doing research on the install as its not plug and play. What did you end up going with for your entire system?
08-18-2021, 08:10 PM | #313 | |
Rep 23
sukhk5272169.50 |
08-18-2021, 08:12 PM | #314 | ||
Rep 23
08-18-2021, 10:25 PM | #315 | |
Rep 114
Can you expound a little more on the built-in Basser subwoofer box & JL sub? Is it a lot more bass? Does it hit pretty hard? Any comparison to a 10" sub(like under the storage/spare tire compartment )? Did you put in the JL 8w3? |
08-28-2021, 05:45 PM | #316 | ||
Rep 23
Robg1119722.50 |
08-30-2021, 06:23 PM | #317 |
Rep 12
Hi,
Looking at upgrading the base audio ( will do the HU upgrade later as its currently the ENTRYNAV unit) ive decided on the focals below for front/rear speakers and the up-7dsp match amp ( i already had the amp ) https://www.dynamicsounds.co.uk/bmw-...grade-kit.html https://www.audiotec-fischer.de/en/m...ifiers/up-7dsp Whats recommended for the underseat subs ? |
08-30-2021, 06:29 PM | #318 |
Rep 12
Just to add the base system in the UK is a level below what's available in most countries, its 6 speakers, no tweeters or amp
I bought a very odd spec car as it was special build for emergency services, so has some very basic spec ( cloth seats/base stereo/ no navigation ) but has options like air suspension extra large batteries etc fitted |
05-20-2022, 12:34 AM | #319 |
Rep 175
Hello
I have question. I would like to add an additional audio amplifier with extra subwoofer in my bmw X5 F15 with harman kardon system sound (option 688). And here is the question: is this kit plug & play connectable? Logic7/HK/EPS/Individual Audio/Bang & Olufsen/Bowers & Wilkins add-a-sub harness w/LOC-150 Will I need this too? AudioControl LC2i 2 Channel Line Out Converter |
05-20-2022, 06:59 AM | #320 |
873
Rep 345
Just added two 10" to mine. The wiring harness made it a breeze with no cutting.
Yes need lCI 2 line out converter. I have HK system. Added two shallow SKAR 10" with 1200 watt SKAR amp. Used a dual shallow truck box and flipped it to angle with back seat. Didn't lose much space. To access bottom trunk area I just lean both seats forward. Added sooo much more depth and richness to system. HK … to me… has great mids and highs… just needed bass to fill out. |
05-20-2022, 11:41 PM | #321 |
Rep 175
Could you write what exactly I need to buy to connect an additional audio amplifier?
this harness: http://technicpnp.com/product/logic7...harness-wlocx/ or this? http://technicpnp.com/product/logic7...sub-t-harness/ if I understand correctly, in the case of option 1 I will not need AudioControl LC2i 2 Channel? If, however, I choose harness in option 2, I have to buy AudioControl LC2i 2 Channel? which option is easier to connect? And the last question is: which is better? audiocontrols new lc2i or audiocontrols new lc2i PRO? |
05-21-2022, 06:32 AM | #322 |
151
Rep 302
Drives: 2017 BMW X5M
I'm looking at you guys systems like " WHAT ARE THOSE" lol…. My system would shake you guys cars park next to mine lol my shit is crazy loud
06-16-2022, 10:31 PM | #323 |
Rep 175
which one to choose? which will be better to connect a subwoofer?
AudioControl LC2i, 2 Channel Line or AudioControl LC2i PRO 2 Channel? as far as I know the "PRO" version is newer? |
06-19-2022, 03:33 AM | #324 | |
Rep 1,019
