      11-23-2015, 08:55 AM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
IND| F85/F86 Hood Roundel Trim Install
One of the nice design elements featured on BMW M models is the menacing shadow-line black trim. Unfortunately, BMW always leave a few key elements in the standard chrome finish. In continuation of supplanting the BMW chrome accents, one of the first area we decided to address was the chrome BMW roundel housing. This piece is a fairly quick DIY and results in creating a more cohesive look on the F15/F16/F85/F86.
Tools required for this job are follows:
• Painters tape
• Bondo spreader
• Nylon pry tool
• Detail spray
• Adhesive remover
Available for purchase on our website:
https://ind-distribution.com/product...D-F85-HROUNDEL
1. The first and very important step is to protect the vehicle paint. This is done with painters tape from your local auto parts store or hardware store. Once you have the tape, the idea is to create a barrier between the paint and the factory roundel trim.
2. The factory roundel is secured via two tabs as well as a ring of double-sided tape. The double-sided tape is doing most of the work. Carefully place the nylon pry tool in between the body and the roundel trim.
3. Once the roundel is slightly lifted, place the bondo spreader under the roundel and begin to work its way around the circumference of the roundel while slightly lifting the roundel. This will release the double-sided tape.
4. After the tape has been separated from the body, carefully pull on the roundel to release the two tabs. Make sure to keep the factory grommets as you will use them with the new painted roundel.
5. There will be some leftover residue from the double-sided tape. You can remove this with your fingers and a small dab of adhesive remover. Make sure the area is clean and dry before installing the new roundel.
6. Now you can remove the painters tape and clean the surface with a clean microfiber and detail spray.
7. Your replacement roundel trim has pre-installed double-sided tape ready to go. Simply remove the paper covering and guide the trim into place. Apply light pressure around the roundel to promote adhesion between the double-sided tape and the body.
8. Take a step back and admire your work. Please contact us if you have any questions regarding the install.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      11-23-2015, 10:34 AM   #2
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Looks great
      11-23-2015, 11:12 AM   #3
rmreddy5
rmreddy5's Avatar
58
Drives: 2016 X5M, 2015 X5 M-Sport
Wow that car is hot!
      11-23-2015, 03:55 PM   #4
savela
savela's Avatar
Drives: 2015 X5M
So front roundel for my x5M it is!
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      11-23-2015, 10:31 PM   #5
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Nice! You guys can hook me up with one for my e70? Need to match the rear one now.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      11-24-2015, 12:07 AM   #6
Powerbeast
Powerbeast's Avatar
Drives: F80 M3 RarriRot
Stoked to receive mine. Very clean upgrades.
      11-24-2015, 09:06 AM   #7
X5Jouster
X5Jouster's Avatar
110
Drives: X5 xDrive50I Msport
Do you have an install tutorial for the rear roundel emblem?
      11-24-2015, 09:15 AM   #8
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
PM on the way
Got you covered http://f15.bimmerpost.com/forums/sho....php?t=1112728
      11-25-2015, 12:34 AM   #9
bayareabimmer
bayareabimmer's Avatar
60
Drives: '16 X5 ; '16 750i; '15 S550
Can you PM me the rear roundel installation? Thank You.
      11-25-2015, 08:41 AM   #10
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
PM sent
      12-17-2017, 03:29 PM   #11
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
No matter what I do I cannot get anything under my hood roundel. It's on there like crazy and my nylon pry tools aren't thin enough to fit very far under. I can get them under the trunk one but trying to get it into the dish that it sits and under the roundel isn't working. It's nearly flush with the car and every time I seem to be doing nothing but bending the hood down.
Any suggestions are welcome.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      12-17-2017, 10:34 PM   #12
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Ended up using some packing strips that I could shimmy under the lip to pull up an edge to skip the bondo spreaders under and then the nylon pry bar between the spreader and the roundel
'06 C55 AMG (sold)
      12-18-2017, 07:22 PM   #13
J///MJ
J///MJ's Avatar
105
Drives: 2018 x5m black fire edition
Sleek
      12-19-2017, 11:58 PM   #14
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Expensive. But yes I agree!
'06 C55 AMG (sold)
      11-26-2019, 12:59 AM   #15
335i101
335i101's Avatar
Drives: 2008 E60 M5
Any pics of the gloss vs matte roundels?
I am looking for carbon fiber roundels for the trunk and hood of my f85.
Cars color is silverstone.
Also, want matching kidney grills. (No stripes, has night vision) and I would guess it is best to have the color (gloss, matte,etc...) on the emblems and the grill match....I just don't know what to pick..?
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2008 M5 with muffler delete-sold
2007 650i-sold
2008 335i-JB4, DP, Meth-sold
      11-26-2019, 10:47 AM   #16
KCTiger
Drives: 2016 X5M
I have the black chrome roundels. I had to do something with the white and blue wedges so I did vinyl overlays. I wish I had a better option but I like the gray and black look, especially considering how thoroughly black my car is. Pic is attached.
335i10179.00
      11-26-2019, 07:11 PM   #17
335i101
335i101's Avatar
Drives: 2008 E60 M5
Anyone have pics of a Silverstone X5M with a gloss black grill and black roundel?
These things aren't cheap, just want to make sure I order the correct setup...
2021 Mercedes G550
2015 X5M
2020 Supra-JB4, DP
2007 650i-sold
