10-04-2015, 04:25 PM | #23 | |
Rep 145
There is a voltage dependent shutoff mechanism in the car as a second (and in this case, only effective) line of defense. |
10-05-2015, 12:15 PM | #24 |
Rep 256
Drives: '17 F15 MSport
If you have Auto Start/Stop activated, the engine will shut off and the radio will play for as long as you want (or until the battery drains). boom! You're welcome...
10-05-2015, 12:17 PM | #25 |
Rep 5,066
If this works then LOL!
10-05-2015, 12:20 PM | #26 |
Rep 256
10-05-2015, 01:57 PM | #27 |
Rep 1,181
If this is true, then there really are BMW Geniuses! They covered for the "stuck in traffic" scenario and allowed people to listen to soothing music as long as they want vs honking the horn!
Nice job IndyJer!
10-05-2015, 03:28 PM | #28 |
Rep 145
I actually thought about using Auto Start/Stop and tried it once. As soon as I put the car in Park, the dash shows that Auto Start/Stop is disabled.
You say if I also turn on Auto Hold, don't put the car in P, this should work? Will try it this afternoon! Thanks! |
10-05-2015, 04:43 PM | #29 |
Rep 256
Yes it will work. Auto Hold and Auto Start/Stop activated. Its not without some issues, mainly that the entire car (except the engine) is on. HUD, gauges, climate control, etc all stay on and are draining your battery. Shutting the car off and not getting out only leaves iDrive and radio on, so the battery drain is more severe with auto hold + auto start/stop. But it solves your original issue...
10-06-2015, 03:30 PM | #30 | |
Rep 145
As you wrote, everything stays on, including the parking sensors so that needs to be turned off too, but otherwise the setup works. |
05-30-2021, 05:34 AM | #31 |
Rep 1
start/stop killing your starter and not really an option,
So, is there a way to code it somehow without using Auto H/start/stop features? The other day I was at a party near lake and there were no "sound" so I "offroaded" my X6 to the party which was cool and turned on some sick music and had to re-press egnition every 12 minutes or so for 10 TIMES, which was not cool, when you talking with someone or dancing and like "hold on I need to keep it going"... I Agree this is stupid design, back in a day I could enable music on my e46Ci for like 4 hours and than we start it by the "manual run" and that was awesome experience, BMW should disable it when voltage is really low, not every 12 minutes "just in case" |
