10-06-2015, 06:12 PM | #1 |
Rep 299
Need help on front grill installation
I've unscrew the front and try to reach for the tabs, however, I can only find and see one tab on each side. Please see picture below with the arrow.
With only one reachable tab, how did you guys pull this thing out? Or did I miss anything? I looked at Alan's picture on where the tabs are, but it seems like they are not reachable with the grill installed.
10-06-2015, 06:23 PM | #2 |
Rep 1,181
Remove the plastic shroud right above the grilles (has the triangle warning sticker) and you will have all the access you need.
The orig "Dual Slat Grille" thread has further tidbits. Page 4/5 were my install posts. http://f15.bimmerpost.com/forums/sho....php?t=1116604
10-06-2015, 07:10 PM | #4 |
Rep 1,181
All one piece. I went down the same road you did... tried to release the wrong tabs which were the chrome surrounds. Use the new grille to see where the correct tabs are positioned.
10-06-2015, 10:30 PM | #6 |
Rep 1,363
Don't feel too bad. I failed my first time. You need to pull the grille towards yourself as much as possible and search for the tabs. I used fast food chopsticks to get to the ones i couldn't reach
10-07-2015, 02:02 AM | #7 |
Rep 1,181
Some close-up pics of the stock grille and associated tabs.
First pic shows the top three tabs. The chrome surround is attached at the same points, only that those smaller tabs are integrated into the overall/sturdier clips. Second pic shows you the actual clips that hold the entire grille in place. See the middle tab with the indent? Flathead screwdriver fits nicely in there so that you can apply downward pressure as you pull the grille fwd to release the tab. Third pic is a shot of one of the side clips. Both are easily reachable with a screwdriver once the air intake shroud is removed. Last pic is of the grille turned upside down so you can see the bottom three clips. Because these clips need to be pushed upward to release, even though there's room to fit a screwdriver, there is no leverage space. That's why we've all said you have to use your fingers and wedge things upward just enough to release the tension in the clips. That's also why it's imperative you drive around a bit to warm up the plastic. It really does help. Good luck and of course... post pics (both of the grilles as well as your bruised/scuffed hands ) when finished! Will look realllly good on your white car, especially with the Hamanns!
10-07-2015, 07:43 AM | #8 |
Rep 8,808
^^Follow Doanster's advice and you should be good to go.
Key is warm engine and don't be afraid to use some muscle to pull it all out one piece. Once the first one is out the second one is a breeze since you have more room to stick your hand in there now. Alan
10-07-2015, 08:59 AM | #9 |
Rep 12
Alan is spot on with the "warm motor" tip...
I did mine yesterday, and after you get one side out the other is a breeze...it's getting that first one started that takes patience. |
10-07-2015, 10:22 AM | #12 |
Rep 497
Just did this on Sunday.
Have 2 flat head screw drivers ready. (explanation for left grill) 1. open top cover on the Intake. It should be an oval shape. 2. Pull out 2 top clips for grill surround (chrome piece) 3. Slide flat head to unclip the actual grill starting from the top left clip. 4. move on to outer left 5. use the Intake hole to access the bottom clips and just work at it counter clock wise to take off the clips. 6. use the left grill opening to work on the right side. * It's easier to start on the left side because you can use the Intake hole so start with that
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM F80 DCT (18) - Comp - AW F30 6MT 335i - EBII |
10-07-2015, 10:22 AM | #13 |
Rep 1,547
I've done a few grille swaps on various BMW models, and that first one, you're right is always a b*tch to get out it seems. I'm always cautious not to force it and break those tabs off.
10-07-2015, 11:43 AM | #14 |
Rep 497
eh~ breaking 1 should be fine haha
F85 (17) - DG/AB
10-07-2015, 03:27 PM | #16 | |
Rep 5,066
10-07-2015, 04:34 PM | #17 |
Rep 18,713
Come on guys, not that hard.
I just drop an X5, install a dual slat kidney grill, and painted reflector in 3 hours, that includes lunch break.
10-07-2015, 05:26 PM | #19 | |
Rep 1,181
10-07-2015, 10:42 PM | #21 |
Rep 132
10-07-2015, 11:15 PM | #22 |
170
Rep 386
