      11-30-2017, 08:59 AM   #1
fromkrypton
Drives: 2015 X5 35d
2015 BMW X5 35d  [0.00]
35d water pump and oil change interval
Just wondering at what mileage do we change water pump on a F15 35d. Also how often are oil changes done for a diesel?
Thanks!
      11-30-2017, 10:27 AM   #2
Mr.47
Mr.47's Avatar
480
Drives: F15 X5 35d
Per BMW
Coolant Lifetime *
Waterpump Lifetime**
Oil Change 10k or 1yr with LL04 or LL14fe+ spec oil
*Coolant replace if cooling system serviced otherwise top off, first change 150k mi or 8 yrs otherwise maintenance free.
** Replace if there is a fault ie leaking or overheating, otherwise maintenance free
__________________________________________________ ________________
My Recommendations
Oil change 7500 mi or 1 yr with LL04** depending on driving habbit
Coolant 75k mi or 4 yrs first change thereafter 3 yrs or 50k mi
Waterpump Replace at 100k miles regardless of symptoms or not.
**Recommend Mobil 1 ESP 5w-30 (LL04 spec) for motor oil
__________________________________________________ _________________
I changed my own coolant it was rather involving have to remove the radiator fan to access a coolant bypass hose which was the lowest part of the cooling system and also your radiator drain plug (this radiator has no actual drain plug) See below for guide.
http://f15.bimmerpost.com/forums/sho...php?p=22438405
